Internet Connection
sbsi_cisco
I had a question regarding a PIX 506e firewall and a Catalyst 2960 switch and setting up internet access. Everything worked fine before I decided to subnet the internal network, I had it set up so the internet can be used and RDP can be passed through the firewall, ever sense I decided to subnet the network, I can still get RDP to pass through the firewall but I can not connect to the internet inside the network. Any advice would be much appreciated, thanks in advance!
Greg LePage
Wilson Samuel
Level 7
Level 7
Hi Greg,
Please correct me if required, are you trying to say that, you are not able to get to the Internet from Inside network ever since you have subnetted?
Moreover, please paste the config so that we may be able to better understand the situation.
Kind Regards,
Wilson Samuel
