Internet Load Balancing IOS
Has anyone sucessfully implemted Internet Load Balancing with OER with help of following config. example by cisco
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
If yes please check my config . Sometimes internet works dead slow but i can see NAT entries and sometimes IP SLA will always fail . If i remove that tracking and put static routes it seems to work fine .
Has anyone implemented this sucessfully in production networks ?
Router#sh run
Building configuration...
Current configuration : 2147 bytes
version 12.4
hostname Router
boot-start-marker
boot system flash c1841-advsecurityk9-mz.124-24.T3.bin
boot-end-marker
logging message-counter syslog
enable password cisco
no aaa new-model
dot11 syslog
ip source-route
ip cef
archive
log config
  hidekeys
track 1 ip sla 1 reachability
default-state up
delay down 15 up 10
track 2 ip sla 2 reachability
default-state up
delay down 15 up 10
interface FastEthernet0/0
description ISP 1
ip address 10.2.2.211 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description ISP 2
ip address 192.168.1.211 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1/0
switchport access vlan 20
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Vlan1
no ip address
interface Vlan20
description LAN INTERFACE
ip address 172.16.1.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.2.2.1 track 1
ip route 0.0.0.0 0.0.0.0 192.168.1.1 track 2
ip http server
no ip http secure-server
ip nat inside source route-map dhcp-nat interface FastEthernet0/0 overload
ip nat inside source route-map fixed-nat interface FastEthernet0/1 overload
ip sla 1
icmp-echo 4.2.2.2 source-interface FastEthernet0/0
frequency 5
ip sla schedule 1 start-time now
ip sla 2
icmp-echo 4.2.2.2 source-interface FastEthernet0/1
frequency 5
ip sla schedule 2 start-time now
access-list 110 permit ip 172.16.1.0 0.0.0.255 any
route-map fixed-nat permit 10
match ip address 110
match interface FastEthernet0/0
route-map dhcp-nat permit 10
match interface FastEthernet0/1
control-plane
line con 0
line aux 0
line vty 0 4
no login
scheduler allocate 20000 1000
end
It sems fine but as most cisco things it should be verified live.
Note if you're using isp modem/router with nat, it would be better to configure them in bridge modem, and bring the public address directly to the router.
5 Replies 5
paolo bevilacqua
Try updating IOS.
Note you don't need mss adjust.
Also there is to see why the tracking fails.
Do you think configuration is fine ? Any recommendations for the IOS , should i try 15.x ?
Thats what I was thinking of yesterday . Because the Cisco router is doing NAT and then the ISP Modem/Router is doing NAT again this can be a problem .
I will test this out somehow and let you know .
I tested it with the public IP terminated on routers and it worked great . IPSLA did had some problems and thus I put static routes for the ip to which icmp packets were being sent and created default route with track .
