Internet Redundancy across Sites
jennyjohn
We are planning for redundancy for Internet connectivity with the Primary Internet connection at the Head Office and the Secondary Internet connection at the DR site (Diagram attached).
By default all MPLS Sites (Site1 & Site2) should access internet via Head Office. In the event of the Internet at Head Office fails, the MPLS sites should access internet via the DR Site. Is this implementation possible?
The same Service Provider provides the Internet and MPLS connections for all the sites. Also the Service Provider has implemented SLA (using BGP) for all the MPLS sites.
Thanks in advance.
andrew.prince
Level 10
Level 10
Yes it is possible.  I suggest you speak to your ISP, as they are doing everything else for you.
HTH>
