Internet routers BGP / OSPF config
carl_townshend
Hi all
Can anyone confirm or help me to see how our internet routers are set up
We currently have 2 internet routers both on different ISP's
we receive a default route on both, these routers then connect to some internal routers using OSPF which advertises our PI address range.
1 internet router is active, the other is currently in standby both in and out
I asked the consultant how they are set up for resilience, the reply was
"the backup internet router just learns the route from the first – if it sees the route in the table it doesn’t advertise it itself out to the internet"
what does thsi mean and how would you think it is set up ?
cheers
Pedro Lereno
Hi Carl,
I think the backup router has an ibgp connection to the active one, has a lower local-preference to its wan link (outbound traffic) and advertises your ip address space with as-path prepending or some communities agreed with the ISP (inbound traffic).
You can check this video for local preference and as-path prepend: http://youtu.be/DVT1y1oSLUs
And this for bgp communities: http://youtu.be/xVQlYPWOCYE
Pedro Lereno
