ip tcp adjust-mss command
mmendis
Hi all ,
Is it ok to configure ip tcp adjust-mss command on ISP level Gateway router ???
8 Replies 8
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Sure.  Although, I'm curious why you would.
Thanks Joseph, Could you please refer this thread ?
https://supportforums.cisco.com/thread/2241302
mmendis
By enabling this arn't we overloading the router ???
Disclaimer
Posting
No, in fact, it often decreases the load on the router (especially if fragmentation is avoided).
BTW, mss-adjust shouldn't be needed for the network to transfer data, it's a optimization feature.  If it is needed, there's an issue with PMTUD.
Thanks Joseph,
If it's using as a optimization feature why I shouldn't use it ???
Disclaimer
Posting
If used appropriately, don't see a reason why you wouldn't want to use it.
Disclaimer
Posting
Thanks Joseph,
Is there any proper document I can follow before I implement it ?
Disclaimer
Posting
Oriented for tunnels, but adresses avoiding fragmentation, http://www.cisco.com/en/US/tech/tk827/tk369/technologies_white_paper09186a00800d6979.shtml
