Internet Sharing For two VLANs
chalilakath
Dears
I have internet connection for VLAN 100 and I need to share the same connection with VLAN 200 also. Is it possible? If yes, please let me know how to configure on CISCO 2960 Switch.
robjw85
I don't believe that 2960 switches support inter-vlan routing. In order to share the connection you will need a device that can operate at layer 3. You could either upgrade to a multi-layer switch or get a router and configure "router on a stick."
