Intervlan problem
vishwancc
Level 3
Level 3
Hi ALL:
I have 3 vlan on 4503 switch .
When i am trying to copy data within vlan say vlan2 to vlan2 its very fast but when i am doing intervlan vlan2 to vlan3 copying its very very slow.
Port speed ,cables are all swapped and changed theer is no STP loop no high CPU.
All the devices are connected to 1 switch no other switch is involved in between,no access-list.
I have tried hard to find what could be the problem but was not able to.
Chao
Vishwa
Rupesh Kashyap
Please initiate Extended ping from Client Switch to L3 Switch. Send more packets. See the result. Please pay attension on Default-Gateway configuration on Client too.
Hi Rupesh,
Client and server are connected to the same switch .
I have already done extented ping and there were some drop even there is no mmismatch in speed .
And default gateway is fine on the clients
Chao
