InterVlan routing is not working
hello friends. i have created 6 Vlans and their respective SVi on core witch and then i created SVi for management on other switches which is different subnet , ip routing is enabled on core, management SVI can communicate between switches but when i try to ping from Access layer switch where i created an SVI management . it can ping the different subnet i.e other SVIs on core , ? Need help
Junaid Shah
Share your config
Julio E. Moisa
Could you please share your configuration, are you passing the vlans through the trunks?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
I was on site at that moment when this issue accured, i enabled routing and rip was not working, then i changed it to ospf and it started working, Thanks guys. for responding :)
one thing that i wanna mention. i just tried to enable ip routing on other switches too, with ip routing commnd and it stopped pinging to the other switches when i disabled it started working.any idea why it happened
