Intervlan Routing Issue
sharma.advait
I am not able to communicated between vlan 1, 2,3, although inter vlan routing is enabled on cisco 3750 l3 switch.
Bellow is the configuration.
Please suggest on it
APHS_CORE#sh running-config
Building configuration...
Current configuration : 7022 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname APHS_CORE
enable secret 5 $1$ZIFI$evixjAIDgo9nV/451.v9U0
enable password 7 14050107
no aaa new-model
switch 1 provision ws-c3750g-48ts
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
description WS-038
switchport access vlan 2
spanning-tree portfast
interface GigabitEthernet1/0/2
description WS-010
interface GigabitEthernet1/0/3
description WS-007
interface GigabitEthernet1/0/4
description WS-009
interface GigabitEthernet1/0/5
description UD01
switchport access vlan 3
storm-control multicast level 0.05
interface GigabitEthernet1/0/6
description PI01
interface GigabitEthernet1/0/7
description PI02
interface GigabitEthernet1/0/8
description LP01
interface GigabitEthernet1/0/9
description HL01
interface GigabitEthernet1/0/10
description EN02
interface GigabitEthernet1/0/11
description HL02
interface GigabitEthernet1/0/12
description WS-011
interface GigabitEthernet1/0/13
description OT1DF2
interface GigabitEthernet1/0/14
description PB2LP1
interface GigabitEthernet1/0/15
description PB1CS12
interface GigabitEthernet1/0/16
description PB6LP1
interface GigabitEthernet1/0/17
description PB1HL1
interface GigabitEthernet1/0/18
description WS-039
interface GigabitEthernet1/0/19
description LP02
interface GigabitEthernet1/0/20
description LP03
interface GigabitEthernet1/0/21
description EN01
interface GigabitEthernet1/0/22
description PB2HL1
interface GigabitEthernet1/0/23
description HL03
interface GigabitEthernet1/0/24
description PB1CS34
interface GigabitEthernet1/0/25
description RB01
interface GigabitEthernet1/0/26
description DR-SERVER-LEVEL1
interface GigabitEthernet1/0/27
description DR-SERVER-LEVEL2
interface GigabitEthernet1/0/28
description SAL-SERVER1-LEVEL1
interface GigabitEthernet1/0/29
description SAL-SERVER2-LEVEL1
interface GigabitEthernet1/0/30
description SAL-SERVER1-LEVEL2
interface GigabitEthernet1/0/31
description SAL-SERVER2-LEVEL2
interface GigabitEthernet1/0/32
description CR-WS01-LEVEL2
interface GigabitEthernet1/0/33
description CR-WS02-LEVEL2
interface GigabitEthernet1/0/34
description CR-WS03-VLAN1
interface GigabitEthernet1/0/35
description CR-WS04-VLAN1
interface GigabitEthernet1/0/36
description CR-WS05-VLAN1
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
switchport mode trunk
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
ip address 10.36.24.1 255.255.255.0
standby ip 10.36.24.4
interface Vlan2
ip address 10.36.25.241 255.255.255.0
standby ip 10.36.25.243
standby priority 110
interface Vlan3
ip address 10.36.26.241 255.255.255.0
standby ip 10.36.26.243
ip classless
ip route 0.0.0.0 0.0.0.0 10.36.24.3
ip http server
ip access-list extended SAL1
permit udp 10.36.26.0 0.0.0.255 host 10.22.19.16
permit udp any any
ip access-list extended SAL1_out
permit ip host 10.22.19.16 10.36.26.0 0.0.0.255
permit ip host 10.2.219.91 10.36.26.0 0.0.0.255
permit ip host 10.2.161.16 10.36.26.0 0.0.0.255
permit ip host 10.44.108.110 10.36.26.0 0.0.0.255
ip access-list extended SAL2
permit ip 10.36.25.0 0.0.0.255 host 10.22.19.16
permit udp any any
permit ip 10.36.25.0 0.0.0.255 host 10.44.108.110
permit ip 10.36.25.0 0.0.0.255 host 10.2.219.91
deny   ip any any
ip access-list extended SAL2_out
permit ip host 10.2.161.16 10.36.25.0 0.0.0.255
permit udp any any
permit ip host 10.22.19.16 10.36.25.0 0.0.0.255
permit ip host 10.44.108.110 10.36.25.0 0.0.0.255
permit ip host 10.2.219.91 10.36.25.0 0.0.0.255
access-list 101 deny   ip any any
access-list 102 deny   ip any any
access-list 111 deny   igmp any any
snmp-server community public RO
snmp-server location APHS Control Room
snmp-server contact Suresh Malviya
control-plane
line con 0
line vty 0 4
password 7 104F191116
login
line vty 5 15
password 7 141602031F
login
end
16 Replies 16
Tharak,
Sorry. I directed the question to you, but it was meant for the OP.
John
HTH, John *** Please rate all useful posts ***
francisco_1
Level 7
Level 7
Advait,
The switch configuration looks OK!!!
I am trying to understand from what are you pinging from and to what?
Are the PC's you ping from and to are on the same switch?
What is the PC default gatway IP & MAC address?
Is the APHS_CORE connected to another switch / HSRP ?
Can you provide a connectivity diagram?
If you can provide the info above then we shoudl be able to assisit you further
Francisco
