Intervlan routing on layer 3 switch - does it require ip addresses? or will trunks work?
Matt Dunleavy
I am trying to get my head around intervlan routing and the thing that keeps me going in circles is the layer 3 switch does it need to ip addresses i.e gateways on the vlans of the layer 3 switch?
If we trunk from a router the vlans will the layer 3 switch be smart enough to first send to router and then do its internal switching inside.
These are exactly correct; both will accomplish what you want and both will work. I set up my networks more in the line of the second diagram. The only change is that I don't use a VL:AN between the switch and the ASA/router. I will designate a port on the switch as a routed port (interface command no switchport), once you do this you will assign an IP address to that port like you do for a router's port. For instance in your second diagram I would assign 10.16.1.1/30 to the ASA and assign 10.16.1.2/30 to the interface on the switch. Your diagram will work just as well as my modification however. You will need to assign a gateway of 10.16.1.1 to the switch.
Sam
13 Replies 13
Joseph W. Doherty
For an L3 switch to route, it needs interfaces with IPs.  This could be routed port interfaces and/or SVIs.  If using SVIs, would could route between them while using a trunk port.
When you say you can route between then while using a trunk port are you talking about another set of switches below the layer 3 switch i.e 2 layer 2 switches connected to a different vlan? But the L3 switch will still need vlan IPs to be able to route? correct?
Matt, I think you are confusing yourself talking about L3 and trunks; they are two different parts of the OSI layer and should not be interchanged.
Inter VLAN routing happens at layer 3 in a switch; within that switch you have multiple VLANs. Each VLAN has a Switch Virtual Interface (SVI), this is the VLAN interface which has an IP address assigned to the SVI. As you add VLANs and SVIs the switch will build a routing table similar to what you see in a router or a PC. Like any other IP network device (in your case the L3 switch) you have to assign an IP address (one for each VLAN or SVI) and a default router. This default route will be to a boundary devices usually a router or in your case an ASA. The only real difference for inter VLAN routing is that the switch has multiple VLANs, SVIs and IPs. Below are the VLANs I have on my L3 switch and appropriately the routing table from that switch:
interface Vlan100
 description SERVERS
 ip address 10.244.0.1 255.255.255.0
 no ip route-cache
 no ip mroute-cache
interface Vlan200
 description RNT-LAB
 ip address 10.19.9.1 255.255.255.224
 no ip route-cache
 no ip mroute-cache
interface Vlan250
 description BUILD LAB
 ip address 10.19.9.33 255.255.255.224
 no ip route-cache
 no ip mroute-cache
interface Vlan300
 description RNT-HOME
 ip address 10.19.8.1 255.255.255.0
 no ip route-cache
 no ip mroute-cache
interface Vlan500
 description WIRELESS
 ip address 10.19.9.193 255.255.255.192
 no ip route-cache
 no ip mroute-cache
interface Vlan550
 description GUEST WIRELESS
 ip address 10.19.9.129 255.255.255.192
 ip access-group 155 in
 no ip route-cache
 no ip mroute-cache
interface Vlan900
 description MANAGEMENT
 ip address 10.244.3.193 255.255.255.192
 no ip route-cache
 no ip mroute-cache
Routing table...
Gateway of last resort is 10.13.13.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 10.13.13.1
      10.0.0.0/8 is variably subnetted, 16 subnets, 5 masks
C        10.13.13.0/30 is directly connected, GigabitEthernet0/1
L        10.13.13.2/32 is directly connected, GigabitEthernet0/1
C        10.19.8.0/24 is directly connected, Vlan300
L        10.19.8.1/32 is directly connected, Vlan300
C        10.19.9.0/27 is directly connected, Vlan200
L        10.19.9.1/32 is directly connected, Vlan200
C        10.19.9.32/27 is directly connected, Vlan250
L        10.19.9.33/32 is directly connected, Vlan250
C        10.19.9.128/26 is directly connected, Vlan550
L        10.19.9.129/32 is directly connected, Vlan550
C        10.19.9.192/26 is directly connected, Vlan500
L        10.19.9.193/32 is directly connected, Vlan500
C        10.244.0.0/24 is directly connected, Vlan100
L        10.244.0.1/32 is directly connected, Vlan100
C        10.244.3.192/26 is directly connected, Vlan900
L        10.244.3.193/32 is directly connected, Vlan900
In the routing table you will see a /32 address, this is the SVI IP address and the various subneted addresses are the individual VLAN addresses. The only address I manually added was the gateway of last resort, everything else was built off of the SVIs and subnets by the switch.
Hope this help!
Sam
Hi there,
Thank you for this, yes I was getting confused, I was thinking that if the ASA trunked the vlans to the L3 switch, that the layer 3 switch would then see that it has these vlans on different physical ports and instead of sending the traffic back to the ASA, it would instead switch inside the L3 switch between the trunked vlans.
Now that I have written this out it sounds a bit dumb(sorry a i'm still learning this stuff)
So I have created 2 diagrams, can you tell me which would be the better way to go about it?
Diagram 1 ASA shares vlan with Web servers, static route for on web servers to sql servers
diagram 1
Diagram 2 (3 Vlans - no static routes on servers, only on ASA):
Diagram 2
Sam
Hi Sam,
Thank you for this, I was reading some cisco documentation and saw this exactly what your talking about
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/45002-intervlan3750-45002.html
So yes, I think this is better. I am hoping the ASA NAT rules will still NAT properly too with out having to change them and use the static routes to get to them, it should shouldn't it?
Diagram 3
The simple thing to do for the router and NAT translations is to use a continuous block of addresses. For instance from the ASA send back 172.16.1.0/22, this will equate to 172.16.1.1 through 172.16.3.254. Once you send the entire block back to the switch you can segment it as you need. The only thing you need to change in the ASA if you need more addresses is the subnet for the NAT process. In your example you have to NAT three different subnets.
Sam
Hi Sam,
This is exactly what we do now, we NAT the outside ip ranges to only 172.16.1.x /24 range addresses, which is our web servers. We don't NAT to any other network ranges.
Thank you for your help today, I am very much appreciative.
Glad I could help!
Hi Sam,
Not sure if you can help further, but how do I setup the ASA to forward its DMZ subnet via a static route to the SVI?
Hi Matt,
I don't know that I can help you on this; I have no knowledge of the ASA devices. I will give you a link to a discussion on how I would handle this in an IOS device. The first thing I will tell you is that a true DMZ will send all traffic for a given public IP to a host(s) so that the host(s) can offer services to the client.
In an IOS device I send ports to individual servers based on the services they offer. That is to say I will send tcp/udp 53 to one machine, tcp 25 to another and tcp 80 to another for example. Keeping this in mind you will understand the following post a little better.
I do not know if the ASA manages these in the same way or not.
https://supportforums.cisco.com/discussion/11738651/multiple-wan-ip-addresses-and-multiple-inside-hosts
Sam
Richard Burts
You are asking two questions.
The first question asks whether the layer 3 switch needs IP addresses to do inter vlan routing and the answer is that yes the switch must have an IP address in each vlan for which it will do inter vlan routing. If the layer 3 switch does not have an IP address in some particular vlan then the switch can not do inter vlan routing for that vlan.
I do not understand what you are trying to ask in your second question about sending first to the router and then doing its internal switching. Can you clarify your question?
Rick
Rick
So we have an ASA firewall, with 3 networks outside, SQL (192) and WEB (172). The plan is to move the WEB and SQLto the layer 3 switch because the ASA firewall can not handle the amount of traffic that our webservers are communicating with our SQL.
If I trunk the SQL Vlan and Web Vlan to the layer 3 switch, will they still use the ASA to switch traffic, or will the layer 3 switch know that it contains those vlans and switch internally rather than going to the ASA?
or will I need to move the ASA vlans to the layer 3 switch and bascailly set static routes in the asa to point to the interface on the switch.?
