Invalid timer / Route Age in EIGRP
gauravprakash
Do we have any invalid timer/max age concept associated with routes learned by EIGRP. How does EIGRP maintains this...
Thx,
G
EIGRP does not use invalid timer/max age like OSPF. The route gets removed only if it receives an update to that effect from the neighbor who originated the route or if the neighbor itself goes down.
Here's a topology capture of a route and the actual route in the FIB. It only tells you the age of the route in the FIB and that's it.
R2#show ip eigrp top 1.1.1.1 255.255.255.255
IP-EIGRP (AS 1): Topology entry for 1.1.1.1/32
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 409600
Routing Descriptor Blocks:
172.30.1.11 (Ethernet0/0), from 172.30.1.11, Send flag is 0x0
Composite metric is (409600/128256), Route is Internal
Vector metric:
Minimum bandwidth is 10000 Kbit
Total delay is 6000 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1500
Hop count is 1
R2#show ip route 1.1.1.1
Routing entry for 1.1.1.1/32
Known via "eigrp 1", distance 90, metric 409600, type internal
Redistributing via eigrp 1
Last update from 172.30.1.11 on Ethernet0/0, 01:17:58 ago
* 172.30.1.11, from 172.30.1.11, 01:17:58 ago, via Ethernet0/0
Route metric is 409600, traffic share count is 1
Total delay is 6000 microseconds, minimum bandwidth is 10000 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
Hope that helps!
Sundar
