Investigating IOS version 12.2(25)SEE2
richardpierce
I am trying to investigate an IOS version which we are currently running. The problem is that I can't find any information on CCO I can see that 12.2(25)SEE3 & 12.2(25)SEE4 are both deferred but there is no informtion on 12.2(25)SEE2. Can I assume that 12.2(25)SEE2 is also deferred?
5 Replies 5
Jon Marshall
Richard
As far as i can tell 12.2(25)SEE2 is not a deferred release. It has however been removed from software download so you may want to consider uupgrading. Having said that if it has all the features you need and is working properly then maybe best to leave well alone :-)
Jon
Laurent Aubert
Laurent
When you say "Yes" do you mean it is deferred ?
Jon
That's correct.
Laurent.
Laurent
Sorry for being a bit dense but where in the document does it say anything about deferred releases ?
Jon
