03-21-2010
07:13 PM
- last edited on
03-25-2019
03:28 PM
by
ciscomoderator
I have a 2901 is running IOS 15.0. I can't any bfd command under interface. It's only used "bfd all-interface" under the routing protocol.
Is it need more other license?
Solved! Go to Solution.
03-21-2010 11:39 PM
Use the 'compare images' option of the Cisco Feature Navigator.
03-21-2010 09:38 PM
Quite possible. Can you post the output of show licensing all?
jerry
03-21-2010 10:43 PM
The 2901 is only IP BASE license.
I have to found bfd function in the DATA License.
How do I to know all feature of DATA license?
03-21-2010 11:39 PM
