IOS Backup
sham_chennala
HI,
I know how to take the backup of IOS through TFTP.Is there any other method available for taking the backup.
Pls Answer for me.
Thanks & Regards
Sham.
Goutam Sanyal
Level 4
Level 4
Yes,
1. There is another option to take backup with the help of PENDRIVE. If the router has the USB port.
#copy usb flash:FLASH_NAME.bin
2. Via FTP u can also do the same.
#copy ftp:URL_NAME
3.Via http and https u can do the same.
#copy http flash:
Address or Name of remote host []:
Hope it will help you.
Goutam
Please rate if it helps you!!!
Goutam Sanyal
Level 4
Level 4
Yes,
#copy ftp:URL_NAME
#copy http flash:
Goutam
Hi Goutam,
Can you explain the second step through Ftp
and 3rd step through http.
Thaknks for your replay,
Sham.
Sure!!!
As per my 2nd post:
#copy ftp flash:
Address or host name of remote host []? YOUR_FTP_SERVER's_IP_ADDRESS
Source File Name []?Flash_Name.bin
Destination filename []?AS_TYPED_SOURCE_FILE_NAME
#copy http: flash:
Destination filename [http]?
(folloe the same as above)
Not only that you can also copy the runing/startup config.
Goutam
Please rate if it helps u!!!
