Cisco Router on Embarq DSL with Redback
scott.k.logan
Ok, so I've got Embarq DSL, and they gave me one of those 660 modems and it works okay. What I'm trying to do, is get my Cisco 2610 with a WIC-1ADSL to take care of routing and tranceiving the connection. I've confirmed my configuration multiple times, and still nothing. I finally talked to Embarq, and they said that they showed a physical connection, but my connection wasn't "registering" properly with Redback. Is it possible to configure my Cisco router to work like this? How does Redback work?
--scott
7 Replies 7
paolo bevilacqua
They work with PPPoE (always involved when there's redback). So you need to configure your router for PPPoE. If you think you have partially done so already, send here the relevant config you have.
Here is my running config:
version 12.3
service password-encryption
hostname CNRouter
boot-start-marker
boot-end-marker
enable secret 5 $1$xxxxxxxxxxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxx
no aaa new-model
ip subnet-zero
ip cef
bridge irb
interface ATM0/0
description WAN Connection
no ip address
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
bridge-group 1
pvc 8/35
encapsulation aal5snap
interface Ethernet0/0
ip address 192.168.1.99 255.255.255.0
ip nat inside
half-duplex
interface Serial0/1
no ip address
shutdown
interface BVI1
ip address 65.41.113.xxx 255.255.255.128
ip nat outside
ip default-gateway 65.41.113.1
ip nat inside source list 1 interface BVI1 overload
ip http server
ip classless
access-list 1 permit 192.168.1.0 0.0.0.255
bridge 1 protocol ieee
bridge 1 route ip
line con 0
login
line aux 0
line vty 0 4
login
end
Thanks for your help!
--scott
No, that's not pppoe.
One example:
http://cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a6c3.shtml
hope this helps, please rate post if it does!
I looked into PPPoE, and it doesn't quite look right. Embarq says I'm not a PPPoE customer, and I set the encoding on the old 660 modem to RFC 1483 and that worked. In talking more with embarq, they seem to be saying that there isn't any "authentication" happening, but that the redback server cross checks the IP address with its own records, and that the connection just isn't getting that far.
Ok, then try that:
interface ATM0/0
no ip address
bundle-enable
no bridge-group 1
no pvc 8/35
int atm 0.1 point-to-point
bridge-group 1
pvc 8/35
check with show atm pvc is packets are sent and received on the pvc.
Okay, tried that, and I get the same kinda stuff.
I try: ping 65.41.113.1 source bvi1 and I get nada. Here is my sh int and sh run:
CNRouter#sh int
ATM0/0 is up, line protocol is up
Hardware is DSLSAR (with Alcatel ADSL Module)
Description: WAN Connection
MTU 4470 bytes, sub MTU 4470, BW 448 Kbit, DLY 4570 usec,
reliability 248/255, txload 1/255, rxload 1/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
23 maximum active VCs, 256 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input 00:14:48, output 00:00:00, output hang never
Queueing strategy: Per VC Queueing
110 packets input, 9326 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 13 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
146 packets output, 6810 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
ATM0/0.1 is up, line protocol is up
MTU 4470 bytes, BW 448 Kbit, DLY 4570 usec,
Encapsulation ATM
0 OAM cells input, 0 OAM cells output
AAL5 CRC errors : 0
AAL5 SAR Timeouts : 0
AAL5 Oversized SDUs : 0
BVI1 is up, line protocol is up
Hardware is BVI, address is 0000.0cf0.ea33 (bia 0004.9a8f.c920)
Internet address is 65.41.113.117/25
MTU 4470 bytes, BW 448 Kbit, DLY 5000 usec,
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/0 (size/max)
0 packets input, 0 bytes, 0 no buffer
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
9 packets output, 540 bytes, 0 underruns
CNRouter#sh run
Building configuration...
Current configuration : 1088 bytes
version 12.3
hostname CNRouter
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
username cottsay password 7 xxxxxx
bridge irb
interface ATM0/0
no ip address
bundle-enable
interface ATM0/0.1 point-to-point
bridge-group 1
pvc 8/35
ip nat inside
half-duplex
interface Serial0/1
no ip address
shutdown
no fair-queue
interface BVI1
ip address 65.41.113.xx 255.255.255.128
ip nat outside
ip nat inside source list 1 interface ATM0/0.1 overload
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 65.41.113.1
line con 0
line aux 0
line vty 0 4
password 7 xxx
login
end
This one is easy to miss and in fact is missing:
bridge 1 route ip
let us know!
