IOS Bug for 11.2(17)p?
kelvin-yeo
Hi Guys,
My old Cisco2501 is running on the above IOS.
I am not able to console into the router USING the console port, BUT i could USING the AUX port!
Is it a bug?
cheers,
kelvin
7 Replies 7
Harold Ritter
It might be a problem with the console port configuration. What is the configuration for the console port?
Hi hritter,
Theres no config on the console.
Please let me know any other infomation you required.
Thanks.
Kelvin
Do you get any junk characters on your console ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
No junk characters. give a blank terminal until i change to the AUX port.
Do you need my 'Show-Tech' ?
Troubled,
Kelvin
what is the config-register value. ?? please check . and see whta configurations of console do u connect in ..these both shud match......
bye
do tell the results..
pushkar1782,
Something bad happened!
When i tried to connect to the AUX with 9600,8 data,None parity, 2 stop bits, i am not able to access anymore.
Now i lost total terminal connection to the router!!!
Help!
kelvin
Hi Guys,
i received these characters when i connect to the console port.
ÿÿÿßßÿÏÿÿÿÿ
Troubled,
kelvin
