IOS Feature Set
gavin.mckee
How do I find out the feature set that is running on an MSFC?
Is there a command or can I just tell from the system image file.
Show version:
IOS (tm) MSFC2 Software (C6MSFC2-PSV-M), Version 12.1(13)E9, EARLY DEPLOYMENT RE
LEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Sun 13-Jul-03 00:49 by hqluong
Image text-base: 0x40008C00, data-base: 0x41880000
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTLDR: MSFC2 Software (C6MSFC2-PSV-M), Version 12.1(13)E9, EARLY DEPLOYMENT RE
itge-dublin-msfc1 uptime is 2 years, 22 weeks, 6 days, 19 hours, 31 minutes
System image file is "bootflash:c6msfc2-psv-mz.121-13.E9.bin"
cisco Cat6k-MSFC2 (R7000) processor with 114688K/16384K bytes of memory.
Processor board ID SAL0708D90B
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Channelized E1, Version 1.0.
X.25 software, Version 3.0.0.
Bridging software.
2 FlexWAN controllers (3 Serial).
17 Virtual Ethernet/IEEE 802.3 interface(s)
3 Serial network interface(s)
509K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x102
desai.jaideep
Level 5
Level 5
I did some searching and yours is SERVICE PROVIDER W/VIP .
Pls Try the following link for more information.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Hope that helps.
Pls rate helpfull posts.
JD
desai.jaideep
Level 5
Level 5
Hope that helps.
JD
minumathur
hi
yes, tool.cisco.com is good tool to do some research on feature set.
-Minu
