IOS for ADSL 2610
mcardell
Good morning,
I need an IOS running on 2610 (not XM) supporting ADSL.
Also if the IOS version is deferred it is not important because it is for testing purpose.
My problem is that I need to respect the memory requirements:
Flash 8 Mbps and Ram 32.
Can you suggest any IOS (I tried feature navigator without success).
Matteo
Hello Matteo,
the Cisco 2610 requires a PLUS IOS image for ADSL if using 12.2T. From 12.3 Mainline and beyond ADSL WIC support is available in the "IP Base" feature set.
The IP Plus image requires 48MB DRAM and 16MB Flash, the IP Base feature set does not seem to be supported on the 2610. Hence it looks like you need to install additional DRAM and Flash and load a 12.2T IP Plus release...
HTH,
GP
thisisshanky
Level 11
Level 11
Like GP suggested, you require more ram/flash to support the newer feature set. Some of the older IOSes that may be smaller in size and requires less ram, may not be downloadable any more (deferred). The quick and easy way is to upgrade IOS, ram, flash. Obviously there is a $$ factor.
Another way to do this is to use an external ADSL modem. Use ethernet hand off to your router and you may configure the modem to bridge all traffic, while the router does PPPOE. Again to do PPPOE, you need more RAM and Flash.
PS: Please remember to rate helpful replies!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
