IOS image
vishwancc
Level 3
Level 3
Hi Guys,
Is there a IOS image that i can use with 3475 router and get SSH 3 support as a feature.
Chao
Vishwa.
Mark Yeates
Level 7
Level 7
Vishwa,
I don't believe SSH version 3 is available in Cisco IOS. I also did a quick check to make sure I wasn't missing anything using the software advisor. The latest version you can use is SSHv2.
HTH,
Mark
Thanks Mark.
