IOS Image
sudhir1972hk
I recently obtained a Cisco 2621 Router from a friend. My colleague was playing with it and accidentally deleted the IOS image on the router and now I am stuck with the rommon prompt. Could any of you guys help me get an IOS image? Thanks a lot.
5 Replies 5
ohassairi
Level 5
Level 5
try to search internet for such IOS. you can find it in some share web sites.
you need a soft as small as the size of your flash.
if you have an other router you can copy the ios from it and then download it to the first one.
I did search the net but couldn't find it. Hope you can guide me a website that shares the IOS images. Also, I can't load other router's IOS onto this router, right?
network_dude
If you are in ROMmon and there is no IOS image in flash: You will need to do an Xmodem transfer (This could take hours).
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
As far as obtaining an image, you can tftp the image from another 2621 to you local PC.
Scott
Hi Scott,
The problem is I don't have another 2621 Router. Doesn't Cisco provide the IOS image?
If you have a valid account you can login to cisco.com and download the image.
