IOS names command
HI all,
I want to implement naming in an IOS router in the following way that the ASA does it. For instance in ASA i can do the following:
name Server1 192.168.0.1
access-list outside-in extended permit tcp any host Server1 eq http
The question is can i do that in a router? Because when i try to put something like
ip host Server1 192.168.0.1
ip access-list extended outside-in
it automatically translates it to an IP address, and when i do a show run i get the following:
Router# sh access-list outside-in
Extended IP access list outside-in
    10 permit ip any host 192.168.0.1 any (17 matches)
Is there a way to show the access-list entries in naming? The sh ver output is the following:
LOGBG>sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 23-Mar-10 06:43 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
LOGBG uptime is 1 week, 4 days, 11 hours, 47 minutes
System returned to ROM by bus error at PC 0x4177FC80, address 0x931B at 14:19:32 EEST Tue Sep 7 2010
System restarted at 14:21:29 EEST Tue Sep 7 2010
System image file is "flash:c2800nm-advsecurityk9-mz.124-24.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FCZ101470JQ
7 FastEthernet interfaces
1 Serial(sync/async) interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
TIA, Nicos Nicolaides
Edison Ortiz
ip host is for internal name resolution purposes - you are looking for the object group command.
Please refer to the documentation:
http://www.cisco.com/en/US/docs/ios/sec_data_plane/configuration/guide/sec_object_group_acl_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Edison Ortiz
Thank you , will give it a shot
