IOS PPTP & Logging
bjssccouser
I have setup a 2600 series router running 12.3 IOS to provide PPTP client VPN access. All authentication requests etc are logged by the RADIUS server, however, I would also like the router to log user access to the syslog server i.e. date/time connected, username, disconnect time etc.
Currently only this is logged whenever a user connects/disconnects:
13/03/2009 14:41:19 Notice 363: *Mar 3 20:21:13.158: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access4, changed state to up
13/03/2009 14:40:19 Notice 361: *Mar 3 20:20:12.430: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access7, changed state to down
13/03/2009 14:40:18 Error 360: *Mar 3 20:20:11.437: %LINK-3-UPDOWN: Interface Virtual-Access7, changed state to down
13/03/2009 14:35:51 Error 358: *Mar 3 20:15:44.190: %LINK-3-UPDOWN: Interface Virtual-Access7, changed state to up
This is my config:
aaa new-model
vpdn enable
vpdn logging
vpdn logging user
vpdn-group VPN
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
interface Virtual-Template1
ip unnumbered FastEthernet0/1
peer default ip address dhcp
compress mppc
ppp encrypt mppe auto required
ppp authentication ms-chap-v2
ppp timeout idle 21600
logging x.x.x.x
Any help would be graetly appreciated.
gmarogi
Level 5
Level 5
The interface hardware has gone either up or down.
Recommended Action: If the state change was unexpected, confirm the configuration settings for the interface.
The data link level line protocol has changed state.
Recommended Action: No action is required.
