Problem upgrading cisco 1841 to 12.4(15)T
I'm trying to upgrade my cisco 1841 to 12.4(15)T IOS (to use an additional network adapter) but for the moment I can't. I delete from flash:/ the old image file 12.4(3i) and then I upload, with tftp, the new file c1841-ipbasek9-mz.124-15.T.bin. When I do the reload the router can't boot and enter the rommon mode. The message is:
"Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x177037c
*** TLB (Store) Exception ***
Access address = 0x454e
PC = 0x802000f0, Cause = 0xc, Status Reg = 0x3041e803
monitor: command "boot" aborted due to exception
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 platform with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled"
From the rommon mode I can reload the old good image file and restart the router correctely.
Thanks very mutch.
Riccardo Maciocco
Edison Ortiz
Riccardo,
It may be a sign the image is corrupted.
Upload the image once again and make sure to run a verify on the image before rebooting the router
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_t1.html#wp1028453
The md5 output from the verify should match the md5 printed on the download page.
HTH,
__
Edison.
