IOS Query for Lan to LAN VPN
padraig.oreilly
Hi all,
I'm trying to setup a Lan to LAN tunnel at present via my vpn 2 concentrators, with an 837 on one side and a 2651xm on the other.
The vpn is established fine and the 837 is sending packets but the 2651 is making no attempt to reply.
I've a large number of scenarios and I'm starting to think it is my IOS.
The 2651Xm is running
c2600-advipservicesk9-mz.123-6e
Is this sufficient to do what I want to do.
Richard Burts
As far as I know the advanced IP services image c2600-advipservicesk9-mz.123-6e should support VPN just fine.
Just to clarify one aspect, your message talks about VPN between two concentrators and talks about 837 and 2651. Am I correct that the 837 and the 2651 are the concentrators doing the VPN?
Your message says the VPN is established so I assume that it is not an issue with configuration of the VPN. If the 837 is sending but the 2651 is not responding I can think of a few things that might cause this:
- are the packets perhaps leaving the 837 but not getting to the 2651? (one way to check this would be to turn on debug icmp on the 2651 and then ping the 2651 from the 837.)
- if the packets do get to the 2651 it might be possible that it does not have a correct route back to the 837. (the output of show ip route should clarify that.)
- if you are doing NAT there might be something in the NAT configuration that is getting in the way of successful communication.
If you could provide a little information about the topology of the network (what addresses are where and how are things connected) and post the configs we might be able to help you find the issue.
Rick
Rick
