IOS router source NAT for a unconnected network
mag2suban
Would want to inside  source NAT an IP address which is not direclty attached to the NAT  inside interface ,,,it is a hop away from the inside interface...Appreciate pointers!
2 Accepted Solutions
Jeff Van Houten
Level 5
Level 5
Just configure as if the host were in the same subnet as one of the interfaces. Ip nat inside on the interface closest to the host.
cadet alain
2points:
1) permit this subnet in your NAT ACL
2) make sure the router doing NAT has a route for this subnet.
Alain
Jeff Van Houten
Level 5
Level 5
cadet alain
2points:
Alain
