IOS Software Matrix
jcoreano
Does anybody knows how to get the IOS matrix for the CISCO 1720. That will include all the version and memory requirements.
r-frank
Got to the Software advisor tool and use add the specific features you require for your 1720 and then it will do a search for you and give you many options. But as far as I know there is no actual 'Matrix' like I think you want.
http://tools.cisco.com/Support/Fusion/FusionHome.do
