IOS upgrade on Nexus7018
mohammedrafiq
Hi all,
I am trying to upgrade IOS on my Nexus7018 from version 5.12 to 5.13. I have managed on all my three out of four Nexus succesfully but one of them is keep coming with this error,
""""N1K-7018-1# install all kickstart bootflash:n7000-s1-kickstart.5.1.3.bin system bootflash:n7000-s1-kickstart.5.1.3.bin
Another install procedure may be in progress. Please try later.
Any idea how to find out which other install is running or stop any install procedure.?
Regards.
8 Replies 8
Roman Rodichev
Level 7
Level 7
try "show install all status"
7018-1#  sh install all status
No installation has taken place since the last reboot.
7018-1# sh install all failure-reason
No install all failure-reason
do you have two sups? do a sup switchover to see if this issue gets cleared up. If you have one sup, can you reboot it?
Check the command that you are using, your output shows that you are using the kickstart as the system
image also.
HTH,
jerry
Good call!
But it still same, We do have daul SUP and next failover to standby
But it still same, We do have daul SUP and next I will failover to backup SUP and trry again,
-7018-1# dir bootflash:
        510    Apr 01 17:19:36 2011  TBM14434529_150299013.lic
        510    Dec 07 21:20:38 2010  TBM14434590_150299013.lic
        510    Apr 01 17:27:36 2011  TBM14462888_150299013.lic
        510    Apr 01 12:18:42 2011  ftp
  145426381    Dec 07 21:20:04 2010  n7000-s1-dk9.5.1.1.bin
  146170914    Jan 31 22:13:02 2011  n7000-s1-dk9.5.1.2.bin
  146701191    Apr 29 14:06:12 2011  n7000-s1-dk9.5.1.3.bin
   30456320    Dec 07 21:18:45 2010  n7000-s1-kickstart.5.1.1.bin
   30687232    Jan 31 22:20:14 2011  n7000-s1-kickstart.5.1.2.bin
   30674944    Apr 29 14:01:41 2011  n7000-s1-kickstart.5.1.3.bin
   11211205    May 06 13:01:38 2011  show_tech_out.gz
  145426381    Apr 01 14:45:47 2011  tftp
       4096    Dec 07 21:59:38 2010  vdc_2/
       4096    Dec 07 21:59:38 2010  vdc_3/
       4096    Dec 07 21:59:38 2010  vdc_4/
       2728    May 04 16:32:30 2011  vlan.dat
Usage for bootflash://sup-local
  814530560 bytes used
1024327680 bytes free
1838858240 bytes total
-7018-1# install all kickstart bootflash:n7000-s1-kickstart.5.1.3.bin system bootflash:n7000-s1-dk9.5.1.3.bin
yes, try switchover, it won't drop any packets (unless you have some issue going on), and then try the command again
