IOS Upgrade Test Plan
aaldijaili
Does anyone have, or has anyone seen a good IOS Upgrade test plan. I need to write one, and don't want to reinvent the wheel.
not sure if this is what you are looking for, but have a look at the links below:
Cisco administration 101: Upgrading routers and switches
http://techrepublic.com.com/5102-1035-5693872.html
Four Steps to the Right IOS
http://www.cisco.com/warp/public/784/packet/techtips.html
GP
Thanks, but I was looking for more of a test plan for testing protocols and features. Not a how to for IOS upgrades.
For instance. To test OSPF you would config the process, place a couple interfaces in OSPF turn on your authentication, and check the other router to see if routing information is being learned dynamically.
Very general I know but that's what I was looking for.
