IOS Version for 2651XM with NM-4T1-IMA
jmlester
Cisco's documentation on the 2600-series indicates that the NM-4T1-IMA card is supported in the 2651XM router. I cannot seem to find an IOS version that supports it though. The Software Advisor tool always times out when I use this hardware config. Does anyone know what version I need? All I need is basic routing functionality with BGP.
Jason
6 Replies 6
paolo bevilacqua
Any recent version should work.
That's what I thought too, but no go. I just tried 12.4-15-T9 in both ipbase and entbase. The boot loader shows this:
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
00036F 0X00103980 C2651XM Dual Fast Ethernet
0000BC 0X0025178C Four port T1 Inverse Mux for ATM
0X00098670 public buffer pools
0X00211000 public particle pools
TOTAL: 0X005FE77C
So, it sees the card. Once IOS loads though, show inv:
Router#show inv
NAME: "2651XM chassis", DESCR: "2651XM chassis"
PID: C2651XM-2FE , VID: 2.0, SN: JAE#####X##
NAME: "Unknown on Slot 1", DESCR: "Unknown"
PID: , VID: 1.0, SN: FOC#####XX#
No interfaces show up for it either.
Jason
Probably a stupid question, but does the NM-4T1-IMA network module also require that the router have the AIM-ATM installed? I am wondering if that might be the issue?
I had an extra AIM-ATM card, but that did not help. On bootup, I get this:
*Mar 1 00:00:07.660: %PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 188)) is no
t supported on this image.
Please issue "show diag" in fully loaded IOS image
to get the PA's information and verify if it is supported
by this image, a newer version may be needed.
show diag displays:
Slot 1:
Unknown (type 188) Port adapter
Port adapter is disabled
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
Top Assy. Part Number : 800-03974-03
Board Revision : D0
Deviation Number : 0-0
Fab Version : 05
PCB Serial Number : FOC#####XX#
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : NM-ATM-4T1=
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 BC 41 01 00 C0 46 03 20 00 0F 86 03
0x10: 42 44 30 80 00 00 00 00 02 05 C1 8B 46 4F 43 30
0x20: 37 32 30 31 47 41 36 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
jmlester
This version worked:
c2600-is-mz.123-26.bin
They must have removed support for some of the older cards in the 12.4 version.
Jason
They do strange and undue things sometime. Good that you had the perseverance of keep trying.
