IOS XE Nested Policy Traffic Shaping Config
xcz504d1114
Level 4
Level 4
I am running into an issue nesting policy-maps on the IOS XE. I have tested the configuration on IOS and it works fine, but XE gives me errors, stating it can't apply a default policy type inside of a default policy type:
An overview of what I am trying to accomplish, I have an MPLS connection at my datacenter, and for simplicity sake, we will say 3 remote locations.
The datacenter side has a 100 meg connection, and each site has different bandwidth amounts, site 1 = 50, site 2 = 40, site 3 = 10 mbps.
To keep packets from being dropped by the carrier policier when traffic is going from the datacenter to any individual site, I want to traffic shape based on destination.
Here is the configuration I am trying to build, it works on IOS, but not XE (ASR and CSR's, multiple code revisions)
ip access-list extended Site1_Subnets
permit ip 0.0.0.0 0.0.0.0 10.1.1.0 0.0.0.255
ip access-list extended Site2_Subnets
permit ip 0.0.0.0 0.0.0.0 10.1.2.0 0.0.0.255
ip access-list extended Site3_Subnets
permit ip 0.0.0.0 0.0.0.0 10.1.3.0 0.0.0.255
class-map match-any Site1_Class
match access-group name Site1_Subnets
class-map match-any Site2_Class
match access-group name Site2_Subnets
class-map match-any Site3_Class
match access-group name Site3_Subnets
policy-map Site1_Policy
class Site1_Class
shape average 50000000
set cos 3
policy-map Site2_Policy
class Site2_Class
shape average 40000000
set cos 3
policy-map Site3_Policy
class Site3_Class
shape average 10000000
set cos 3
policy-map Datacenter_100Mbps
class class-default
  shape average 100000000
  queue-limit 512 packets
  set cos 5
  service-policy Site1_Policy
  service-policy Site2_Policy
  service-policy Site3_Policy
This is the error I get when I try to nest the policies (this is done on a CSR in a lab, same error on an ASR in production):
ASR-MPLS-1(config-pmap-c)#policy-map Datacenter_100Mbps
ASR-MPLS-1(config-pmap)#class class-default
ASR-MPLS-1(config-pmap-c)#  shape average 100000000
ASR-MPLS-1(config-pmap-c)#  queue-limit 512 packets
ASR-MPLS-1(config-pmap-c)#  set cos 5
ASR-MPLS-1(config-pmap-c)#  service-policy Site1_Policy
Queueing policy Site1_Policy attached to class with random-detect or queue-limit configured is not supported
% service-policy Site1_Policy of type default is not allowed in policy-map Datacenter_100Mbps of type default
xcz504d1114
Level 4
Level 4
Found the problem, queue limit is not supported in hierchical policy-maps in IOS XE
We had encountered this problem on the below IOS XE code, while trying to add a nested service-policy with random-detects and queue limits.
Cisco IOS Software [Fuji], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.8.1, RELEASE SOFTWARE (fc3)
Error:
Queueing policy WAN_Service_Policy attached to class with random-detect or queue-limit configured is not supported
% service-policy WAN_Service_Policy of type default is not allowed in policy-map WAN_Interface_Service_Policy of type default
> However, a similar configuration worked on an earlier IOS XE code.
Cisco IOS XE Software, Version 03.16.02.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSAL-M), Version 15.5(3)S2, RELEASE SOFTWARE (fc2)
 class class-default
  shape average 195136000 780544 0 account user-defined 28
We would love to know if someone has a fix to this.
