IOS-XR BGP best path selection
Hi everyone,
Could someone please explain, why second path is best? I'd appreciate any advice or useful links.
Thanks in advance.
BGP routing table entry for 0.0.0.0/0, Route Distinguisher: 65000:20
Versions:
Process bRIB/RIB SendTblVer
Speaker 1317286004 1317286004
Last Modified: Nov 16 02:42:09.323 for 1w1d
Paths: (3 available, best #2)
Not advertised to any peer
Path #1: Received by speaker 0
Local
10.254.89.61 from 0.0.0.0 (10.254.90.19)
Origin incomplete, metric 11264, localpref 100, weight 32768, valid, redistributed
Received Path ID 0, Local Path ID 0, version 0
Community: 65000:20190
Extended community: COST:128:129:11264 EIGRP route-info:0x0:0 EIGRP AD:10:538 EIGRP RHB:255:2:256 EIGRP LM:0x0:1:1500 EIGRP AR:10:10.254.89.24 EIGRP PM:3:0 RT:65000:20 RT:65000:2000
Path #2: Received by speaker 0
Local
10.254.90.9 (metric 9) from 10.254.156.1 (10.254.90.9)
Received Label 492312
Origin incomplete, metric 3328, localpref 50, valid, internal, best, group-best, import-candidate, not-in-vrf
Received Path ID 0, Local Path ID 1, version 1317286004
Extended community: COST:128:129:3328 EIGRP route-info:0x0:0 EIGRP AD:10:768 EIGRP RHB:255:2:2560 EIGRP LM:0x0:1:1500 EIGRP AR:10:10.254.89.23 EIGRP PM:3:0 RT:65000:20 RT:65000:2000
Originator: 10.254.90.9, Cluster list: 10.254.156.1
Path #3: Received by speaker 0
Local
10.254.90.9 (metric 9) from 10.254.156.7 (10.254.90.9)
Origin incomplete, metric 3328, localpref 50, valid, internal, import-candidate, not-in-vrf
Originator: 10.254.90.9, Cluster list: 10.254.156.7
Harold Ritter
Hi @KirylAviaryanau5293 ,
You can use the keyword "bestpath-compare" to get more information about why bgp selected a given path.
show bgp ipv4 unicast 0.0.0.0/0 bestpath-compare
Here's an example:
RP/0/0/CPU0:R1#show bgp ipv4 unicast 0.0.0.0/0 bestpath-compare
Wed Nov 24 14:11:33.577 UTC
Versions:
Speaker 6 6
Last Modified: Nov 24 13:54:54.521 for 00:16:39
Paths: (2 available, best #1)
Advertised IPv4 Unicast paths to update-groups (with more than one peer):
0.2
0.2
192.168.12.2 from 192.168.12.2 (192.168.100.2)
Origin IGP, metric 0, localpref 100, valid, external, best, group-best
Received Path ID 0, Local Path ID 1, version 5
Origin-AS validity: (disabled)
best of AS 2, Overall best
192.168.13.3 from 192.168.13.3 (192.168.100.3)
Origin IGP, metric 0, localpref 100, valid, external, group-best
best of AS 3
Higher router ID than best path (path #1) <+++++++++++++++++
RP/0/0/CPU0:R1#
It has worked. Thanks a lot.
Hello
I would say path two is selected over path three due to lowest cluster-id ( router id)  - Curious to what does best path shows?
Kind Regards
Paul
