09-24-2018 09:33 AM - edited 09-24-2018 09:41 AM
When looking at my last hop router, the router receiving IGMP Join messages for S,G (210.15.41.41, 232.41.41.41), I do not see it sending PIM Joins being sent upstream towards the branch/intermediate node. I "debug pim all" on both the last hop and intermediate node, after "clear pim topology [232.41.41.41|232.42.42.42]". One would think this is indicative of a RPF check fail, but that does not appear to be the case. What is going on here?
Configuration / Output
RP/0/RP0/CPU0:D21-HHRC01#show run multicast-routing multicast-routing address-family ipv4 interface Loopback0 disable ! interface Loopback1 disable ! multipath ssm range ACL-SSM-GROUPS oom-handling rate-per-route interface all enable accounting per-prefix ! !
RP/0/RP0/CPU0:D21-HHRC01#show run ipv4 access-list ACL-SSM-GROUPS Mon Sep 24 12:27:16.668 EDT ipv4 access-list ACL-SSM-GROUPS 10 permit ipv4 224.0.0.0 15.255.255.255 any !
RP/0/RP0/CPU0:D21-HHRC01#sh pim neighbor Mon Sep 24 12:35:32.034 EDT PIM neighbors in VRF default Flag: B - Bidir capable, P - Proxy capable, DR - Designated Router, E - ECMP Redirect capable * indicates the neighbor created for this router Neighbor Address Interface Uptime Expires DR pri Flags 2.21.22.21* GigabitEthernet0/0/0/0 3d21h 00:01:25 1 B E 2.21.22.22 GigabitEthernet0/0/0/0 3d21h 00:01:14 1 (DR) B 220.21.43.21* GigabitEthernet0/0/0/2 3d21h 00:01:16 1 B E 220.21.43.43 GigabitEthernet0/0/0/2 3d21h 00:01:19 1 (DR)
RP/0/RP0/CPU0:D21-HHRC01#show run router pim Mon Sep 24 12:27:16.281 EDT router pim address-family ipv4 log neighbor changes interface GigabitEthernet0/0/0/0 ! interface GigabitEthernet0/0/0/1 ! interface GigabitEthernet0/0/0/4 ! ! !
RP/0/RP0/CPU0:D21-HHRC01#sh run int gi0/0/0/0 Mon Sep 24 12:27:17.079 EDT interface GigabitEthernet0/0/0/0 mtu 9100 ipv4 address 2.21.22.21/24 ipv6 nd suppress-ra ipv6 address 2002:21:22::21/64 load-interval 30 !
RP/0/RP0/CPU0:D21-HHRC01#show pim rpf 210.15.41.41 Mon Sep 24 12:27:17.452 EDT Table: IPv4-Multicast-default * 210.15.41.41/32 [200/48] via GigabitEthernet0/0/0/0 with rpf neighbor 10.255.0.7
RP/0/RP0/CPU0:D21-HHRC01#show pim topology 232.41.41.41 Mon Sep 24 12:27:17.585 EDT IP PIM Multicast Topology Table Entry state: (*/S,G)[RPT/SPT] Protocol Uptime Info Entry flags: KAT - Keep Alive Timer, AA - Assume Alive, PA - Probe Alive RA - Really Alive, IA - Inherit Alive, LH - Last Hop DSS - Don't Signal Sources, RR - Register Received SR - Sending Registers, SNR - Sending Null Registers E - MSDP External, EX - Extranet MFA - Mofrr Active, MFP - Mofrr Primary, MFB - Mofrr Backup DCC - Don't Check Connected, ME - MDT Encap, MD - MDT Decap MT - Crossed Data MDT threshold, MA - Data MDT Assigned SAJ - BGP Source Active Joined, SAR - BGP Source Active Received, SAS - BGP Source Active Sent, IM - Inband mLDP, X - VxLAN Interface state: Name, Uptime, Fwd, Info Interface flags: LI - Local Interest, LD - Local Dissinterest, II - Internal Interest, ID - Internal Dissinterest, LH - Last Hop, AS - Assert, AB - Admin Boundary, EX - Extranet, BGP - BGP C-Multicast Join, BP - BGP Source Active Prune, MVS - MVPN Safi Learned, MV6S - MVPN IPv6 Safi Learned (210.15.41.41,232.41.41.41)SPT SSM Up: 3d20h JP: Null(never) RPF: GigabitEthernet0/0/0/0,2.21.22.22 Flags: GigabitEthernet0/0/0/2 3d20h off LI
RP/0/RP0/CPU0:D21-HHRC01#show mrib route 232.41.41.41 Mon Sep 24 12:27:17.701 EDT IP Multicast Routing Information Base Entry flags: L - Domain-Local Source, E - External Source to the Domain, C - Directly-Connected Check, S - Signal, IA - Inherit Accept, IF - Inherit From, D - Drop, ME - MDT Encap, EID - Encap ID, MD - MDT Decap, MT - MDT Threshold Crossed, MH - MDT interface handle CD - Conditional Decap, MPLS - MPLS Decap, EX - Extranet MoFE - MoFRR Enabled, MoFS - MoFRR State, MoFP - MoFRR Primary MoFB - MoFRR Backup, RPFID - RPF ID Set, X - VXLAN Interface flags: F - Forward, A - Accept, IC - Internal Copy, NS - Negate Signal, DP - Don't Preserve, SP - Signal Present, II - Internal Interest, ID - Internal Disinterest, LI - Local Interest, LD - Local Disinterest, DI - Decapsulation Interface EI - Encapsulation Interface, MI - MDT Interface, LVIF - MPLS Encap, EX - Extranet, A2 - Secondary Accept, MT - MDT Threshold Crossed, MA - Data MDT Assigned, LMI - mLDP MDT Interface, TMI - P2MP-TE MDT Interface IRMI - IR MDT Interface (210.15.41.41,232.41.41.41) RPF nbr: 2.21.22.22 Flags: RPF Up: 3d20h Incoming Interface List GigabitEthernet0/0/0/0 Flags: A, Up: 00:17:01 Outgoing Interface List GigabitEthernet0/0/0/2 Flags: LI, Up: 3d20h
Debugging
RP/0/RP0/CPU0:D21-HHRC01#show debug Mon Sep 24 12:27:17.810 EDT #### debug flags set from tty 'vty0' #### ipv4 pim all flag is ON with value '0x1##'
RP/0/RP0/CPU0:D21-HHRC01#show log | i 232.41.41.41 Mon Sep 24 12:32:46.347 EDT RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default Best Matching grange (224.0.0.0,0.0.0.0) for group 232.41.41.41 RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Process source RPF update : RPF VRF null , new RPF VRF null (route_create_in_progress) RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Unlink route RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) MRIB modify, !RPF !RPFID, tid 0xe0000000, RPF Nbr Cleared: 2.21.22.22, RPF-ID 0 RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) Gi0/0/0/0 (ifh 0x1000018) MRIB modify, !A, tid 0xe0000000, use_data 0, LSM-ID 0x00000 RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [-1213655296] MDT Grp lookup: Return no match for grp 232.41.41.41 src 210.15.41.41 in remote list (-) RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF: default (210.15.41.41,232.41.41.41) Processing BGP C-MCAST route RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [-1213655296] Quit intf-eval:TT_DELETE:(210.15.41.41,232.41.41.41), rpf GigabitEthernet0_0_0_0/NULL no bundle RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] pim_rib select_topo: vrf=default, src=210.15.41.41, grp=232.41.41.41, selectmt=1, vrf-rpfucastdefault=0: POL-RESULT: pass=1, vrf=NONE, afi=0, safi=0, table=NONE: RPF-RESULT: selectmt=1, drop=0, defaulttable=1, extranet=0, vrf-ctx=0x55b5ed4c89a8, vrf-name=default, table-ctx=0x55b5ed4ce488,table-safi=2, table-table=default, core-type=CORE_INVALID, lsm-root=255.255.255.255 RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default Source RPF Update (210.15.41.41,232.41.41.41) NULL idb, 0.0.0.0, null (), - Null, 0.0.0.0, null () RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) core type check: current: CORE_INVALID, new: CORE_INVALID, cust_signalling PIM-C-MCAST, change: rec_nbr 1 RD 0 vrf_ri 0 AS 0 cust_sig 0, seg_nh 0 RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) RPF neighbor changed from NULL idb (0.0.0.0) to Null (0.0.0.0) RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [-1213655296] TI-MOFRR:source rpf update event: (210.15.41.41,232.41.41.41) is not a cloned join, returning. RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) MRIB modify, RPF !RPFID, tid 0xe0000000, RPF Nbr Set: 0.0.0.0, RPF-ID 0 RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [-1213655296] Quit intf-eval:TT_UPDATE:(210.15.41.41,232.41.41.41), rpf NULL/Null no bundle RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) NULLIF-skip MRIB modify_idb. ifh 0x0 !A RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) NULLIF-skip MRIB modify_idb. ifh 0x0 A !NS RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Source metric changed from [0/0] to [4294967295/4294967295] RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Start of J/P update source_src RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) End of J/P update source_src RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) MRIB modify, RPF !RPFID, tid 0xe0000000, RPF Nbr Set: 0.0.0.0, RPF-ID 0 RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) NULLIF-skip MRIB modify_idb. ifh 0x0 A RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [-1213655296] MDT Grp lookup: Return no match for grp 232.41.41.41 src 210.15.41.41 in remote list (-) RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41)Gi0/0/0/2 icopy_update_source source->src ole icopy OFF OFF RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Gi0/0/0/2 NO MRIB modify RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Gi0/0/0/2 NO MRIB modify. IC is OFF RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Gi0/0/0/2 FWD state change from Null to Prune RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) Gi0/0/0/2 (ifh 0x1000030) MRIB modify, !F !NS, tid 0xe0000000, use_data 0, LSM-ID 0x00000 RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Start of J/P update source_src RP/0/RP0/CPU0:Sep 24 12:03:47.067 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) End of J/P update source_src RP/0/RP0/CPU0:Sep 24 12:03:47.068 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Processing timers mode RP/0/RP0/CPU0:Sep 24 12:03:47.068 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Gi0/0/0/2 Processing timers RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [6634] VRF : default Source RPF Update (210.15.41.41,232.41.41.41) Null, 0.0.0.0, null (), - GigabitEthernet0_0_0_0, 2.21.22.22, null () , via_mdt RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [6634] pim_sm_route_rpf_update: VRF: default (210.15.41.41,232.41.41.41) nh: 2.21.22.22 nhif 0x1000018, core_type: CORE_INVALID, rec_nbr: 10.255.0.7, rd: 0:0:0, seg_nh: 0.0.0.0 RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [6634] VRF : default (210.15.41.41,232.41.41.41) core type check: current: CORE_INVALID, new: CORE_INVALID, cust_signalling PIM-C-MCAST, change: rec_nbr 1 RD 0 vrf_ri 0 AS 0 cust_sig 0, seg_nh 0 RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [6634] VRF : default (210.15.41.41,232.41.41.41) RPF neighbor changed from Null (0.0.0.0) to GigabitEthernet0_0_0_0 (2.21.22.22) RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [1763358464] TI-MOFRR:source rpf update event: (210.15.41.41,232.41.41.41) is not a cloned join, returning. RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [6634] default : (210.15.41.41,232.41.41.41/32) MRIB modify, RPF !RPFID, tid 0xe0000000, RPF Nbr Set: 2.21.22.22, RPF-ID 0 RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [1763358464] Quit intf-eval:TT_UPDATE:(210.15.41.41,232.41.41.41), rpf Null/GigabitEthernet0_0_0_0 no bundle RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [6634] default : (210.15.41.41,232.41.41.41/32) NULLIF-skip MRIB modify_idb. ifh 0x0 !A RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [6634] default : (210.15.41.41,232.41.41.41/32) Gi0/0/0/0 (ifh 0x1000018) MRIB modify, A !NS, tid 0xe0000000, use_data 0, LSM-ID 0x00000 RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [6634] VRF : default (210.15.41.41,232.41.41.41) Source metric changed from [4294967295/4294967295] to [48/200] RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [6634] VRF : default (210.15.41.41,232.41.41.41) Start of J/P update source_src RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [6634] VRF : default (210.15.41.41,232.41.41.41) End of J/P update source_src RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [1763358464] Cache next: Looked up entry 0.0.0.0(210.15.41.41,232.41.41.41) mdt_type 0x0 (-) in default - Success RP/0/RP0/CPU0:Sep 24 12:03:47.071 EDT: pim[1190]: [1763358464] Route intranet DATA MDT link: VRF default (210.15.41.41,232.41.41.41) RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Process source RPF update : RPF VRF null , new RPF VRF null (route_create_in_progress) RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Unlink route RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) MRIB modify, !RPF !RPFID, tid 0xe0000000, RPF Nbr Cleared: 2.21.22.22, RPF-ID 0 RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) Gi0/0/0/0 (ifh 0x1000018) MRIB modify, !A, tid 0xe0000000, use_data 0, LSM-ID 0x00000 RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [-1213655296] MDT Grp lookup: Return no match for grp 232.41.41.41 src 210.15.41.41 in remote list (-) RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] VRF: default (210.15.41.41,232.41.41.41) Processing BGP C-MCAST route RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [-1213655296] Quit intf-eval:TT_DELETE:(210.15.41.41,232.41.41.41), rpf GigabitEthernet0_0_0_0/NULL no bundle RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] pim_rib select_topo: vrf=default, src=210.15.41.41, grp=232.41.41.41, selectmt=1, vrf-rpfucastdefault=0: POL-RESULT: pass=1, vrf=NONE, afi=0, safi=0, table=NONE: RPF-RESULT: selectmt=1, drop=0, defaulttable=1, extranet=0, vrf-ctx=0x55b5ed4c89a8, vrf-name=default, table-ctx=0x55b5ed4ce488,table-safi=2, table-table=default, core-type=CORE_INVALID, lsm-root=255.255.255.255 RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] VRF : default Source RPF Update (210.15.41.41,232.41.41.41) NULL idb, 0.0.0.0, null (), - Null, 0.0.0.0, null () RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) core type check: current: CORE_INVALID, new: CORE_INVALID, cust_signalling PIM-C-MCAST, change: rec_nbr 1 RD 0 vrf_ri 0 AS 0 cust_sig 0, seg_nh 0 RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) RPF neighbor changed from NULL idb (0.0.0.0) to Null (0.0.0.0) RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [-1213655296] TI-MOFRR:source rpf update event: (210.15.41.41,232.41.41.41) is not a cloned join, returning. RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) MRIB modify, RPF !RPFID, tid 0xe0000000, RPF Nbr Set: 0.0.0.0, RPF-ID 0 RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [-1213655296] Quit intf-eval:TT_UPDATE:(210.15.41.41,232.41.41.41), rpf NULL/Null no bundle RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) NULLIF-skip MRIB modify_idb. ifh 0x0 !A RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) NULLIF-skip MRIB modify_idb. ifh 0x0 A !NS RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Source metric changed from [0/0] to [4294967295/4294967295] RP/0/RP0/CPU0:Sep 24 12:10:16.706 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Start of J/P update source_src RP/0/RP0/CPU0:Sep 24 12:10:16.707 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) End of J/P update source_src RP/0/RP0/CPU0:Sep 24 12:10:16.707 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) MRIB modify, RPF !RPFID, tid 0xe0000000, RPF Nbr Set: 0.0.0.0, RPF-ID 0 RP/0/RP0/CPU0:Sep 24 12:10:16.707 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) NULLIF-skip MRIB modify_idb. ifh 0x0 A RP/0/RP0/CPU0:Sep 24 12:10:16.707 EDT: pim[1190]: [-1213655296] MDT Grp lookup: Return no match for grp 232.41.41.41 src 210.15.41.41 in remote list (-) RP/0/RP0/CPU0:Sep 24 12:10:16.707 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41)Gi0/0/0/2 icopy_update_source source->src ole icopy OFF OFF RP/0/RP0/CPU0:Sep 24 12:10:16.707 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Gi0/0/0/2 NO MRIB modify RP/0/RP0/CPU0:Sep 24 12:10:16.707 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Gi0/0/0/2 NO MRIB modify. IC is OFF RP/0/RP0/CPU0:Sep 24 12:10:16.707 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Gi0/0/0/2 FWD state change from Null to Prune RP/0/RP0/CPU0:Sep 24 12:10:16.707 EDT: pim[1190]: [5177] default : (210.15.41.41,232.41.41.41/32) Gi0/0/0/2 (ifh 0x1000030) MRIB modify, !F !NS, tid 0xe0000000, use_data 0, LSM-ID 0x00000 RP/0/RP0/CPU0:Sep 24 12:10:16.707 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Start of J/P update source_src RP/0/RP0/CPU0:Sep 24 12:10:16.707 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) End of J/P update source_src RP/0/RP0/CPU0:Sep 24 12:10:16.710 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Processing timers mode RP/0/RP0/CPU0:Sep 24 12:10:16.710 EDT: pim[1190]: [5177] VRF : default (210.15.41.41,232.41.41.41) Gi0/0/0/2 Processing timers RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [6634] VRF : default Source RPF Update (210.15.41.41,232.41.41.41) Null, 0.0.0.0, null (), - GigabitEthernet0_0_0_0, 2.21.22.22, null () , via_mdt RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [6634] pim_sm_route_rpf_update: VRF: default (210.15.41.41,232.41.41.41) nh: 2.21.22.22 nhif 0x1000018, core_type: CORE_INVALID, rec_nbr: 10.255.0.7, rd: 0:0:0, seg_nh: 0.0.0.0 RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [6634] VRF : default (210.15.41.41,232.41.41.41) core type check: current: CORE_INVALID, new: CORE_INVALID, cust_signalling PIM-C-MCAST, change: rec_nbr 1 RD 0 vrf_ri 0 AS 0 cust_sig 0, seg_nh 0 RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [6634] VRF : default (210.15.41.41,232.41.41.41) RPF neighbor changed from Null (0.0.0.0) to GigabitEthernet0_0_0_0 (2.21.22.22) RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [1763358464] TI-MOFRR:source rpf update event: (210.15.41.41,232.41.41.41) is not a cloned join, returning. RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [6634] default : (210.15.41.41,232.41.41.41/32) MRIB modify, RPF !RPFID, tid 0xe0000000, RPF Nbr Set: 2.21.22.22, RPF-ID 0 RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [1763358464] Quit intf-eval:TT_UPDATE:(210.15.41.41,232.41.41.41), rpf Null/GigabitEthernet0_0_0_0 no bundle RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [6634] default : (210.15.41.41,232.41.41.41/32) NULLIF-skip MRIB modify_idb. ifh 0x0 !A RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [6634] default : (210.15.41.41,232.41.41.41/32) Gi0/0/0/0 (ifh 0x1000018) MRIB modify, A !NS, tid 0xe0000000, use_data 0, LSM-ID 0x00000 RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [6634] VRF : default (210.15.41.41,232.41.41.41) Source metric changed from [4294967295/4294967295] to [48/200] RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [6634] VRF : default (210.15.41.41,232.41.41.41) Start of J/P update source_src RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [6634] VRF : default (210.15.41.41,232.41.41.41) End of J/P update source_src RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [1763358464] Cache next: Looked up entry 0.0.0.0(210.15.41.41,232.41.41.41) mdt_type 0x0 (-) in default - Success RP/0/RP0/CPU0:Sep 24 12:10:16.714 EDT: pim[1190]: [1763358464] Route intranet DATA MDT link: VRF default (210.15.41.41,232.41.41.41) RP/0/RP0/CPU0:Sep 24 12:25:42.502 EDT: pim[1190]: [5177] VRF : default Best Matching grange (224.0.0.0,0.0.0.0) for group 232.41.41.41 RP/0/RP0/CPU0:Sep 24 12:27:17.681 EDT: pim[1190]: [5177] VRF : default Best Matching grange (224.0.0.0,0.0.0.0) for group 232.41.41.41
