IP Accounting question
DanielKerman
Hello everyone!
One of end costumers is trying to configure IP Accounting on 7206 running version 12.4(4)XD8
Here is part of the configuration on the interface:
interface GigabitEthernet0/3.106
bandwidth 1000
encapsulation dot1Q 106
ip address <IP> <SM=/29>
ip verify unicast reverse-path
no ip redirects
ip accounting output-packets
no snmp trap link-status
no cdp enable
The issue we are having is that while the physical interface is up (the sub interface is part of a metro line which is directly connected) we dont see packets being accounted if the destanation IP is down.
Basically we need to know if what we are seeing is normal.
Thanks in advance, Daniel.
Hello Daniel,
Sometimes (not if most of the time) industry standards don't come with official documents. A technology simply becomes the mainstream and everyone adopts it.
Netflow is much more capable than IP accounting. Not sure if your device supports netflow or sflow but try to pair it up with manageengine. they have a 30 day trial. and then see the power of netflow accounting for yourself.
5 Replies 5
Giuseppe Larosa
Hello Daniel,
Do you mean the IPv4 next-hop to the final destination ? or you mean actually the final destination?
What side is starting the communication?
IF it is the IPv4 next-hop to final destination I would say what you see is normal as the route has been removed from IP routing table and from CEF table after next-hop failure, the packets are likely following another path pointing to the default route (if any is present in your environment) and so no IP accounting is performed out the specific interface-
If it is the final destination we need additional information to be helpful
One point can be noted : you have also uRPF configured.
You should provide a network diagram and the configuration of the involved network devices
Hope to help
Giuseppe
Hello Giuseppe, thank you for your reply.
Here are the answers to your quesions:
Both actually. The IPv4 next hop adress is the final destination. During the ocurrence of the problem the interface on the other end acting as the final destination is shut down.
Communaction is starting from the LAN network connected to the 7206, heading for the remote site on the other end of the metro line.
As I said before, its both. When we shut the IPv4 next-hop/Intertfacegshhi, we immediately ping the IP address of the destination. At that moment we dont see packets being accounted.
Can you care to explain how it might be effecting us in the current scenario?
paolo bevilacqua
IP Accounting is obsolete and should not be used. Use netflow instead.
Hello Paolo,
Do you have any official document or source that supports your claim?
I also prefer to use neflow, but an official statement is aways good
Hello Daniel,
