IP address configuration on Cisco 9300
Tazio4436
I have a cisco SW 9300 and it is up and running for nearly 3 years. I thought it is a L3 sw but I tried to configure an Ip address on an interface and i noticed I did not have the option so I added
ip routing
globally and still cannot configure ip address.
I am attaching sh ver
Can some please advise me.
Tazio
2 Accepted Solutions
balaji.bandi
When you like to configure port on the IP configuration
config t
interface TwoGigabitEthernet1/0/1 ( change this to gig if you have gig ports - i used Cat 9300 UXM)
shutdown
no switchport
ip address x.x.x.x 255.255.255.X
no shutdown
You have network advantage License so dont worry License
test and advise.
Note : you are running 16.6 OLD if you get chance upgrade to IOS Xe 17.6.4 latest
BB
Hello ,
Thanks for you reply. It did work.
I will tag this as a solution but open another discussion as I need some other help.
Tazio
balaji.bandi
config t
shutdown
no switchport
no shutdown
test and advise.
BB
Hello ,
Tazio
