IP Addressing
Sulaiman Ejaz
hi !
I'm to ask about IP address classes. Is 10.1.1.1 and 10.2.1.1 same? or 192.168.0.1 and 192.168.1.0 are same? please discuss and provide me some relevant material if anyone has !
cadet alain
the class is derived from first octet value so first 2 are class A and last 2 are class C.
0-127: class A
128-191: class B
192-223: class C
Alain
Hi, thankyou,
if i say i've two ipv4 addresses 192.168.1.1/24 and 192.168.2.1/24 then whats that mean? would both ping each other?
No, not unless you were using a routing device between them as they are in 2 different subnets.
Alain
Yes, both examples.  10.1.1.1 and 10.2.1.1 are both considered class A (but could be different subnets depending on the mask).  192.168.0.1 and 192.168.0.1 are both consider class C.
If this posts answers your question or is helpful, please consider rating it and/or marking as answered.
