ip bandwidth-percent
jim.tagadan
Where to config ip bandwidth-percent eigrp, is it in the physical interface or in the interface tunnel. We have dmvpn design with 2 isp as hub router and 15 spokes. i am confused on the tunnel interface of the dmvpn. what is the best practice? pls help.
Lei Tian
Hi Jim,
That goes to the tunnel interface. The best practice is to configure bandwidth statement on tunnel interface that reflects the physical interface bandwidth; otherwise the tunnel interface will use the default bandwidth value, which might cause issue for EIGRP route update message.
HTH,
Lei Tian
Thanks Lei, appreciating.
