Ip Cef Causing Issues
dcanady55
Level 3
Level 3
Hoping someone can help me. I have a DM VPN connection setup that was working just fine. I added another spoke and was running this out of my office for 4-5 days working just fine. I went on site and discovered I was loosing packets somehow once I tried to go past the hub. Anything directed at the Hub either it be the WAN, Tunnel or hubs LAN I wouldn't loose one packet. After, spending a few days now on the phone with support we shut off IP Cef on the hub and instantly the packets were allowed through. From the other spokes perspective I could ping anything on the network and has not had an issue during all of this. However, from the good spoke I could not ping the bad spoke until we removed the IP cef. We thought there was some bugs close to our issue and upgraded the HUB. No luck.
Any help would be appreciated.
Hello.
If "support" means Cisco TAC - could you please provide your ticket number?
