IP CEF load sharing
We are facing problem with load sharing between two intranet links connected to a Cisco Layer 3 switch. I am thinking of using "ip cef load-sharing algorithm universal ID" command to fix this problem. As per my knowledge Universal logic is the feault one but i want to play around the fixed ID and see if this can be address.
I do not have much idea about selecting which ID to use and i am seeking for more information on this.
Thanks in advance!
paolo bevilacqua
And which problems exactly are you having ? You also have to mention the exact switch type, topology, and traffic flow.
