IP direct-broadcast with standard vs extended ACL
I need to enable directed broadcasts on some SVIs. Is there any difference between me using these two configs:
acl 1 permit 10.10.10.1
int vlan 1
ip directed-broadcast 1
ip forward-protocol udp 10
OR
acl 2000 permit 10.10.10.1 any udp 10
int vlan 1
ip directed-broadcast 2000
Yes, my syntax is not accurate but the point is using a standard ACL with forward-protocol OR using an extended ACL specifying UDP and port; is there a difference in behavior from the end result? There may be in how the packet is processed but if the end result is the same, that's fine.
15 Replies 15
Thanks for the update and the explanation.
Rick
