IP HTTP Server
Ali Norouzi
Cisco routers has internal HTTP server. Can I upload a customized HTML webpage to the router and use its HTTP server to provide service to that simple static HTML page?
Hello
You are able to do this - but I am not sure you should ? - you can copy html files to the router and then specify the http path for you HTML doc
conf t
ip http server
ip http path flash:
res
Paul
Kind Regards
Paul
Hello
conf t
ip http server
ip http path flash:
res
Paul
Kind Regards
Paul
