IP Multicast Rate-Limit ???
I run streaming multicast video cameras on my network.
I stumbled upon the command ip multicast rate-limit.
When I configured a test setup in my lab (mulitcast camera source and a few routers) and tried the command it simply did not work.
Moreover, when I went to use the command on a 3900 router in my lab, it was not there.
I take it this command has been depricated?
Phill
Peter Paluch
Hello Phill,
You are most probably correct: the IP Multicast Command Reference for IOS 15.0M says that the command has been removed in 15.0(1)M and 12.2(33)SRE IOS releases:
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_03.html#wp1063665
Best regards,
Peter
I suppose this command has been discontinued in favor of the IGMP State Limit Feature?
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ft_igmps.html#wp1027184
Hello Phill,
I can not say for sure. IGMP State Limit limits the number of joined groups on an interface or globally per device, while the multicast rate-limit was supposed to drop packets from multicast streams if their amount exceeded a predefined threshold. In a sense, the multicast rate-limit behaved like a traffic policing specifically applied to selected multicast streams. The IGMP State Limit does not directly limit the amount of traffic flowing to a particular multicast group.
Best regards,
Peter
