IP MUX connection to Cisco L3 Switch connecting mainsite to remote sites
Mu Haxy
We have a network setup that is using a RAD IP MUX systems to multiplex t1 lines from one main site to remote sites.  The physical connections looks like below.
IP MUX device --> L3 Switch --> 6509E Core Switch --> Remote L3 Switch (using Lightpath V-line connection) --> IP Mux --> Remote L3 Switch -- >Access layer device(such as phones, faxes, PCs etc).
We configured the network in such a way that the remote sites connect to the mainsite using IP MUX for telephone/voice services.  However, users at remote locations are complaining about noise in their calls as well as having issues with sending faxes. When we check the show interfaces commands, the interface comes out clean.  There is no drop, crc errors or anything unusual.  However, when the RAD team log into the IP mux device, they see incrementing sequence errors being recorded rapidly.  there is no sequence error on the mainsite RAD IP Mux device.  We see sequence errors only on the remote sites.  We use eigrp on the WAN connecting the sites.
  The IP mux team said that even though there are 1Gig interfaces connecting sites, we should configure bandwidth utilization.  However, when i configured bandwidth allocation of 4MB(their recommendation) under the L3 vlans, the situation has not improved.
Would anyone happen to know what may be needed to eliminate the voice noise issues on the remote sites?  Please advise, as i need to get up and running by Wednesday.
L3 Switch Info
L3 Switch#show run int fa1/0/23
Building configuration...
Current configuration : 277 bytes
interface FastEthernet1/0/23
 description Trunk  IPMUX-24 conatins all lines excl ADC
 switchport trunk allowed vlan 745
 switchport mode trunk
 switchport nonegotiate
 power inline never
 speed 100
 duplex full
end
L3 Switch _1#show int fa1/0/23
FastEthernet1/0/23 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 000f.f77f.0899 (bia 000f.f77f.0899)
  Description: Trunk for RAD Voice  IPMUX-24 conatins all lines excl ADC
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 64/255, rxload 64/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 6w4d, output 00:00:01, output hang never
  Last clearing of "show interface" counters 3w2d
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 25365000 bits/sec, 29527 packets/sec
  5 minute output rate 25366000 bits/sec, 29528 packets/sec
     54462354192 packets input, 6069648257408 bytes, 0 no buffer
     Received 40975 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     54463598619 packets output, 6069737555577 bytes, 0 underruns
L3 Switch#show run int gig1/0/1
Current configuration : 148 bytes
interface GigabitEthernet1/0/1
end
6509 Switch connection to L3 Switch
6509#show running-config interface gigabitEthernet xxxx
Current configuration : 207 bytes
interface GigabitEthernetXXXX
 switchport
end
6509#show interface gigabitEthernet xxxx
GigabitEthernet1/2/11 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 000f.908a.c1b2 (bia 000f.908a.c1b2)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 251/255, txload 6/255, rxload 6/255
  Full-duplex, 1000Mb/s, media type is 1000BaseSX
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 25232000 bits/sec, 29322 packets/sec
  5 minute output rate 25688000 bits/sec, 29684 packets/sec
     522352466878 packets input, 54380696803595 bytes, 0 no buffer
     Received 2444519 broadcasts (1272960 multicasts)
     432416694 runts, 0 giants, 0 throttles
     2950494940 input errors, 1038077651 CRC, 1037550737 frame, 0 overrun, 0 ign
Remote Device Connection
To LIGHTPATH
 Remote Switch#show run int gi1/0/4
Current configuration : 196 bytes
interface GigabitEthernet1/0/4
 description LIGHTPATH UPLINK
0 Replies 0
