08-30-2015 09:32 AM - edited 03-05-2019 02:11 AM
Dear All
i configured my cisco router 2911 to work as PPPOE client
when the connection establish it drop immediately
i have another router cisco 1941 it's working fine
i tried to copy the configurations but same issue
exactly the issue appears when Virtual circuit 2 up it comes down after few seconds
this is my configurations
CiscoRouter#show running-config
Building configuration...
Current configuration : 5836 bytes
version 15.4
hostname CiscoRouter
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$m1tN$qC97EEWWMqBHLFhCL4Ysi/
no aaa new-model
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.1.254
ip dhcp pool DHCPPool
network 192.168.1.0 255.255.255.0
dns-server 192.168.1.254 192.168.1.1
default-router 192.168.1.254
lease 30
no ip domain lookup
ip name-server 213.42.20.20
ip name-server 195.229.241.222
ip cef
no ipv6 cef
cts logging verbose
crypto pki trustpoint TP-self-signed-2181142573
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2181142573
revocation-check none
rsakeypair TP-self-signed-2181142573
crypto pki certificate chain TP-self-signed-2181142573
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32313831 31343235 3733301E 170D3135 30323130 32333336
32315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 31383131
34323537 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C1AB B0915790 17DF0077 B47296F0 07E1411A 8E13780D C084290F 3A06D987
BFE5F832 17F5B482 B1928E07 E87CE272 E78C3CB5 38F0B4C8 D77917DA 50B2F887
EB9EC7B3 A02C77AC C7D1D853 1FE4775D 7DDF50F0 D98E2A99 36AD5E86 490747F8
3C55313D CB25EBE2 B2993309 88D431B9 315C3C0B C3CF48BC 32AE5A0D BC74BDE9
68910203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 1430B7C8 538DD742 D526AF2C 0235E8AD 2301A35E 7E301D06
03551D0E 04160414 30B7C853 8DD742D5 26AF2C02 35E8AD23 01A35E7E 300D0609
2A864886 F70D0101 05050003 8181000C 278B2B47 18914344 ECFAEE88 01B3DD1F
21C73F08 032FD7B0 F8E2A7D1 163E15D5 C3D8AE64 D7065CBD F84020E8 3FC7DEA4
9D1E9CE8 21EC324B 4D47A55A 95FC37DE 1BA81144 0CA9EDD1 80344742 0E8A91EB
6C36E361 C05CC577 8C0AD09D 28A85A56 464D8C78 5FBF14CB E98B31A1 2BF95999
16306832 F78B63F4 056209B4 82425A
quit
license udi pid CISCO2911/K9 sn FGL190710Q8
username cisco privilege 15 secret 5 .....
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description WAN Interface
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
description LAN Interface
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
ip tcp adjust-mss 1412
shutdown
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
no ppp authentication chap pap callin
ppp chap hostname UN
ppp chap password 0 PASS
ppp pap sent-username UN password 0 PASS
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 100 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 100 permit ip any any
control-plane
line con 0
password ciscopass
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
CiscoRouter#
