IP Nat conflict question
nemiath76
Greetings,
I have a question regarding ip nat inside command which may explain an issue i am facing with a client..
Suppose we have:
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source static 10.0.0.250 87.202.212.131 route-map NO_NAT
ip nat inside source static 10.0.0.20 87.202.212.132 route-map NO_NAT
ip nat inside source static 10.0.0.60 87.202.212.133
ip nat inside source static 10.0.0.11 87.202.212.134
access-list 101 deny   ip host 10.0.0.30 any
access-list 101 deny   ip 10.254.104.0 0.0.0.255 192.168.146.0 0.0.0.255
access-list 101 deny   ip 10.0.0.0 0.0.0.255 10.254.104.0 0.0.0.255
access-list 101 deny   ip 10.0.0.0 0.0.0.255 10.22.30.0 0.0.1.255
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
and:
route-map NO_NAT deny 10
match ip address no_nat
route-map NO_NAT permit 20
ip access-list extended no_nat
permit ip 10.0.0.0 0.0.0.255 10.254.104.0 0.0.0.255
permit ip 10.254.104.0 0.0.0.255 192.168.146.0 0.0.0.255
in a configuration where 10.0.0.250 87.202.212.131 is the translation of internal exchange address to public mail ip,
Would the ip nat inside source list 101 interface Dialer1 overload conflict with the 1 to 1 map since the 101 list
includes the 10.0.0.250 address?
I am trying to figure out why the exchange exits via the dialer1 ip instead of the mapped one (which results in spam positives for the
receipients.
SOLVED
Rahul Kukreja
I would suggest you to take a looks at this defect -CSCsh21456
Overall precedence looks like
1) Static NAT without Route-maps
2) Dynamic NAT without Route-maps
3) Dynamic NAT with Route-maps
4) Static NAT with Route-maps
The defect is junked as this is day-1 behavior for sorting logic.
Rahul
nemiath76
I figured it out.. Problem was caused by an access-list error.
Access list 101 includes the entire 10.0.0.0 /24 where 10.0.0.250
should be excluded in order to only match the static NAT entry.
I inserted a deny 10.0.0.250 at the top of the 101 ACL and problem is fixed.
