IP NAT help
zeroasylum
I have a Cisco 867VAE-W I was hoping someone would be able to look at my current config and help me to get NAT from outside my network to ip cctv cameras and remoted desktop functionality to work.
I just can seem to get it to work. I have internet access in and out no issues with that but cant get NAT to specific IP's and ports to work.
I have tried the following ip nat inside source static TCP 192.168.1.15 3389 interface Dialer0 3389 and it does appear in the nat translations but does not work. When I execute the command show ip nat translations it does appear but does not work. Some advice and help would be welcome.
I have pasted the config below which I got and modified slightly from my ISP
Zeroasylum
! Last configuration change at 05:21:42 UTC Tue Jan 9 2018 by admin
version 15.3
no service pad
service password-encryption
hostname cisco-867
boot-start-marker
boot-end-marker
aqm-register-fnf
logging buffered 51200 warnings
no aaa new-model
ppp packet throttle 100 1 5
wan mode dsl
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.10.10.2
ip dhcp excluded-address 192.168.1.254
ip dhcp excluded-address 192.168.1.253
ip dhcp pool ccp-pool
 import all
 network 192.168.1.0 255.255.255.0
 default-router 10.10.10.1
 dns-server 203.12.160.35 203.12.160.36
 lease 0 2
ip domain name iinet.net.au
ip name-server 203.0.178.191
ip name-server 203.215.29.191
ip cef
no ipv6 cef
parameter-map type inspect global
 max-incomplete low 18000
 max-incomplete high 20000
flow record nbar-appmon
 match ipv4 source address
 match ipv4 destination address
 match application name
 collect interface output
 collect counter bytes
 collect counter packets
 collect timestamp absolute first
 collect timestamp absolute last
flow monitor application-mon
 cache timeout active 60
 record nbar-appmon
crypto pki trustpoint TP-self-signed-3884120332
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3884120332
 revocation-check none
 rsakeypair TP-self-signed-3884120332
crypto pki certificate chain TP-self-signed-3884120332
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33383834 31323033 3332301E 170D3138 30313039 30303136
  32355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 38383431
  32303333 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C5DA EE73D753 9F9E67F8 84D46687 DDC8A167 0BDF25AD F3B8C701 94B704EF
  324B1B72 75FBECD7 EB3DE70F F5D0393B 826AF8ED C6E7733B 6DE594AE 8350C580
  5656126C BAD5A190 1537144A 0BB90776 08FDF466 442C35B1 574397C7 3AF1ED4C
  5A973557 309F60B8 576AFF26 08F4C396 23F292DB C291A211 147F96C6 547D12FE
  21B70203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1419871C AFA4433A E4B82A40 F984B2E7 49A4C0D9 F7301D06
  03551D0E 04160414 19871CAF A4433AE4 B82A40F9 84B2E749 A4C0D9F7 300D0609
  2A864886 F70D0101 05050003 8181007B F6406FF3 218DD905 AC066B94 C745C5A2
  876A4C29 2EAEC56A 926B5873 53607D9F 687DF263 218D1668 ABD12BCE E88A2E07
  88D4F9F3 AB922998 0AF6205C DE88DC3E F1D959A9 F8587446 D1665CA0 BBB70357
  E56B5F93 C7103505 53FB569D 878BC6C1 613A5400 AEC5A536 2F22FDBB 22A6AB67
  115E93CE 49759659 7404D87C E69941
        quit
object-group service INTERNAL_UTM_SERVICE
object-group network local_cws_net
object-group network local_lan_subnets
 any
object-group network vpn_remote_subnets
 any
username admin privilege 15 secret 5 $1$7D9Y$B60lQY8ApWbPGJQxiTPCg/
username iinet privilege 15 secret 5 $1$nFkx$2l3hAH4AWNrJ9nOh/h4GZ1
crypto key pubkey-chain rsa
 named-key realm-cisco.pub signature
  key-string
   30820122 300D0609 2A864886 F70D0101 01050003 82010F00 3082010A 02820101
   00C19E93 A8AF124A D6CC7A24 5097A975 206BE3A2 06FBA13F 6F12CB5B 4E441F16
   17E630D5 C02AC252 912BE27F 37FDD9C8 11FC7AF7 DCDD81D9 43CDABC3 6007D128
   B199ABCB D34ED0F9 085FADC1 359C189E F30AF10A C0EFB624 7E0764BF 3E53053E
   5B2146A9 D7A5EDE3 0298AF03 DED7A5B8 9479039D 20F30663 9AC64B93 C0112A35
   FE3F0C87 89BCB7BB 994AE74C FA9E481D F65875D6 85EAF974 6D9CC8E3 F0B08B85
   50437722 FFBE85B9 5E4189FF CC189CB9 69C46F9C A84DFBA5 7A0AF99E AD768C36
   006CF498 079F88F8 A3B3FB1F 9FB7B3CB 5539E1D1 9693CCBB 551F78D2 892356AE
   2F56D826 8918EF3C 80CA4F4D 87BFCA3B BFF668E9 689782A5 CF31CB6E B4B094D3
   F3020301 0001
  quit
controller VDSL 0
zone security LAN
zone security WAN
zone security VPN
zone security DMZ
interface ATM0
 no ip address
 no atm ilmi-keepalive
interface ATM0.1 point-to-point
 description pppoe_0_8_35
 pvc 8/35
  pppoe-client dial-pool-number 1
interface Ethernet0
 description -- iiNet FTTN : VDSL2 --
 ip address dhcp
 ip mtu 1452
 ip nat outside
 ip virtual-reassembly in
 no cdp enable
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
 ip tcp adjust-mss 1412
 shutdown
 duplex auto
 speed auto
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
 no ip address
interface Vlan1
 description $ETH_LAN$
 ip address 192.168.1.254 255.255.255.0
 ip nat inside
interface Dialer0
 ip address negotiated
 ip mtu 1452
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication pap callin
 ppp pap sent-username XXXXXXXXX password XXXXXXXX
 ppp ipcp dns request
 no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
no ip nat service sip tcp port 5060
ip nat inside source list 199 interface Dialer0 overload
ip nat inside source list nat-list interface Ethernet0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 Ethernet0
ip access-list extended nat-list
 permit ip object-group local_lan_subnets any
dialer-list 1 protocol ip permit
mac-address-table aging-time 10
no cdp run
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.1.0 0.0.0.255
access-list 199 permit ip any any
line con 0
 login local
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 stopbits 1
line vty 0 4
 access-class 23 in
 privilege level 15
 login local
 transport input ssh
scheduler allocate 60000 1000
end
Helloi
Can you confirm the current setup regards your external wan access?
I see you have to default routes pointing to your dialier and a physical interface and the NAT configuration relating to them.
FYI - you shouldn't use an acl with any any for nat as it could consume unnecessary cpu process, As such its recommend to specify the actual prefix/subnet to be translated
res
Paul
Kind Regards
Paul
1. For RDP to work you will need to rules. RDP uses both TCP 3389 and UDP 3389 so you will need to create two entries. The one you mentioned looks correct but you are missing the one for UDP.
2. It looks like you have two external interfaces so when you create NAT rules for single interface only, you need to connect to the IP for the interface you created rules for. For instance, if you created NAT rules for RDP for Dialer 0, you can’t connect to the RDP using Ethernet 0 public IP. You didn’t mention how you connect so keep that in mind.
3. For cameras, you need to create separate rules for ports they use. If you have multiple cameras listening on the same port, you need to create rules which will use different public ports if you want to have access to all of them at the same time.
Thank you,
Mikolaj
**** PLEASE RATE IF USEFUL. ****
Thank you everyone for the reply's. I am connecting using ADSL on the internal modem. The config was given to me by my ISP and I think it is designed so that they can use it if people are not connecting using the inbuilt ADSL/VDSL modem and instead have a cable modem connected to the wan GE2 port.
I think I may have to start again as this config seems to be a bit of a hack and also as Paul pointed out has an ANY to ANY NAT which is not recommended. Would anyone have a basic config to get me up and running.
Also in the future I will be getting an FTTC connection so will need that wan ge2 port to function as will be connecting that to a separate device to get internet access.
THanks
Zeroasylum
Hello
@zeroasylum wrote:
I Think I may have to start again as this config seems to be a bit of a hack and also as Paul pointed out has an ANY to ANY NAT which is not recommended. Would anyone have a basic config to get me up and running.
Zeroasylum
Inline with the configuration already applied, and your wish to a RDP into the network for host 192.168.1.15. try this:
conf t
no zone security LAN
no zone security WAN
no zone security VPN
no zone security DMZ
no ip nat inside source list nat-list interface Ethernet0 overload
no ip route 0.0.0.0 0.0.0.0 Ethernet0
no ip route 0.0.0.0 0.0.0.0 dialer0
no access-list 199
access-list 199 permit ip 192.168.1.0 0.0.0.255 any
ip route 0.0.0.0 0.0.0.0 dialer 0 dhcp
ip nat inside source static tcp 192.168.1.15 3389 interface Dialer0 3389
ip nat inside source list 199 interface dialer 0 overload
res
Paul
Kind Regards
Paul
