ip nat overloading
saintlan1
in ip nat overloading how many concurrent users would be visible?
dongdongliu
hi
theoretically,more than 60000,
actually,it depends on your equipment`s capability.
Istvan_Rabai
Level 7
Level 7
Hi Froilan,
In NAT overloading you use 1 or a few ip addresses for many connections originating from inside.
If you have one public ip address facing to the outside world, then this one ip address will be seen from outside.
It will be seen as one user runs many applications (with many different source port numbers).
Cheers:
Istvan
