IP NAT Route-map
jurczak
I have just upgraded my 1841 from 12.4.24T1 to 12.4.24T4
after the upgrade the following statement does not seem to work
ip nat inside source route-map VPN_EXCLUDE pool USERS overload
the route-map is configured
route-map VPN_EXCLUDE permit 10
match ip address VPN_NONAT
match interface Dialer0
when I change the statement to
ip nat inside source list VPN_NONAT pool USERS overload
it works fine, but when I use route-map it does not make any translations.
I want to use route-map because I have a dual ISP configuration.
I tried also to upgrade to 15.1.3T but there are no differences, this NAT statement still does not work as it was working with 12.4.24T
0 Replies 0
