IP NAT Static & PAT
tanaka-cm
I would like to make static nat extend for port 1723 (VPN) on
cisco2500.
This router also make nat overload for internet connection also.
my configuration is
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service udp-small-servers
service tcp-small-servers
hostname CMIOFFICE
enable secret xxxx
ip subnet-zero
no ip domain-lookup
ip name-server 203.x.x.242
ip name-server 203.x.x.192.168.1.1
ip dhcp excluded-address 192.168.1.5
ip dhcp pool office
network 192.168.1.0 255.255.255.0
dns-server 203.x.x.71
default-router 192.168.1.5
interface Ethernet0
ip address 192.168.1.5 255.255.255.0
ip nat inside
no ip mroute-cache
interface Serial0
bandwidth 128
ip address 161.87.xx.188 255.255.255.252
ip access-group 101 in
ip access-group 101 out
ip nat outside
encapsulation ppp
no ip mroute-cache
router eigrp 1
network 10.0.0.0
network 192.168.1.0
auto-summary
no eigrp log-neighbor-changes
router rip
network 161.87.137.0
network 192.168.1.0
ip nat inside source list 1 interface Serial0 overload
ip nat inside source static tcp 192.168.1.10 1723 161.87.XX.188 1723
extendable
ip nat inside source static tcp 192.168.1.10 80 161.87.XX.188 80
extendable
ip classless
ip route 0.0.0.0 0.0.0.0 161.87.XX.187
no ip http server
access-list 1 permit any
end
But it not work.
I would like to tracert problem. But I don't know how?
Do you have any recommend configuration?
My Nat translation is
#sh ip nat trans
Pro Inside global Inside local Outside local
Outside global
tcp 161.87.XX.188:1723 192.168.1.10:1723 ---
tcp 161.87.XX.188:80 192.168.1.10:80 ---
Thanks in advance..
If I remember correct, there was a problem to configure PPTP pass-through on IOS (at least I had problems to do the same task on one of my 1712). I tryed to make configuration similar to that described in
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_configuration_example09186a00800949c0.shtml
but never succeeded. The problem was solved only when I took PIX 506 instead of 1712.
It could be that this will work in newer versions of IOS on 17XX (or on another platform - 36XX for example)...
//Mikhail Galiulin
