IP NAT Static with route map and NAT overload
Wan_Whisperer
All,
I have an Issue where I have a network 192.168.1.0/24 needs to have static NAT for two devices and NAT overload for the remainder.  The static NAT's are working but the Overload is not.......
The public IP's below are hidden but highlighted in ORANGE.
My setup
interface GigabitEthernet0/1
Description to Core
ip nat inside
ip address x.x.x.x
interface GigabitEthernet0/2
Description to Rourter7
ip nat outside
ip address x.x.x.x
ip nat pool Pool1 X.X.X.100 X.X.X.100 netmask 255.255.255.0   ***Just using one IP for NAT overload***
ip nat inside source static 192.168.1.101 X.X.X.101 route-map StaticRM
ip nat inside source static 192.168.1.102 X.X.X.102 route-map StaticRM
ip nat inside source list NAT pool Pool1 overload
ip access-list extended NAT   ***If I do not have this, then my static NAT are ignored and everything is NAT overloaded***
deny ip host 192.168.1.101 any
deny ip host 192.168.1.102 any
permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended StaticNat
deny ip 192.168.1.0 0.0.0.255 10.1.1.0 0.0.0.255    ***Do not want this static not when going to Router7***
deny ip 192.168.1.0 0.0.0.255 10.1.2.0 0.0.0.255    ***Do not want this static not when going to Router7***
route-map StaticRM permit 10  ***I have this because I need to exclude the Static NAT for some networks going to Router7***
match ip address StaticNat
Thanks in advance!
Jon Marshall
Replace this line in your route map acl -
with permit lines for each specific host you are doing static NAT for.
Jon
7 Replies 7
static NAT takes precedence, so in theory you would not need the route maps for static NAT. Try the simplified config below:
ip nat inside source list 1 pool Pool1 overload
access-list 1 permit 192.168.1.0
Georg,
Thanks for the input but....If I remove the route map then how will I tell the Static NAT, not to NAT when going to the  10.1.1.0 0.0.0.255 network?
where in your topology is R7 (and networks 10.1.1.024 and 10.1.2.0/24) ? Actually, what does your entire topology look like ?
Hello
Just like to add , i would suggest to keep the specific hosts from the dynamic nat acl and just amend your config a little then test again.
no route-map StaticRM
no ip nat inside source static 192.168.1.101 X.X.X.101 route-map StaticRM
no ip nat inside source static 192.168.1.102 X.X.X.102 route-map StaticRM
Kind Regards
Paul
Paul,
I replied to Georg, the only reason I use the Route map on my static NAT's is to ensure when a packet with a source address of 192.168.1.101 going to 10.1.1.0/24 or 10.1.2.0/24 will not NAT but if it goes to any other network it will NAT
Jon Marshall
Jon
Jon,
Not all heroes wear capes!
You are the Bomb.com
Thanks again...all I needed to do is explicitly list each static NAT in the ACL just like you said.
