IP NAT TRANSALATION FAILING
tefomatlho
HI
i really need assistance, i have configured IP Sla on a 1921, and done nat on all the interfaces, but i get this output from the intefaces;
HAN-C1921-COM#sh ip int br
Embedded-Service-Engine0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0 unassigned YES NVRAM down down
GigabitEthernet0/0.1953 172.16.100.1 YES NVRAM down down
GigabitEthernet0/0.1954 168.167.50.110 YES NVRAM down down
GigabitEthernet0/1 10.10.4.1 YES NVRAM up up
GigabitEthernet0/1/0 unassigned YES NVRAM up up
Dialer1 169.255.81.23 YES IPCP up up
NVI0 unassigned YES unset administratively down down
Virtual-Access1 unassigned YES unset up up
Virtual-Access2 unassigned YES unset up up
please do assist.
Thanking you in advance.
22 Replies 22
post the full configuration of your router....
HAN-C1921-COM#sh run
Building configuration...
Current configuration : 3239 bytes
version 15.4
hostname HAN-C1921-COM
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool TEST
 network 10.10.4.0 255.255.255.0
 default-router 10.10.4.1
 dns-server 8.8.8.8
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1921/K9 sn FGL214493UP
redundancy
track 1 ip sla 1
 delay down 5 up 5
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.1953
 encapsulation dot1Q 1953
 ip address 172.16.100.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
interface GigabitEthernet0/0.1954
 encapsulation dot1Q 1954
 ip address 168.167.50.110 255.255.255.252
 ip nat outside
interface GigabitEthernet0/1
 ip address 10.10.4.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/1/0
 no ip address
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface Dialer1
 ip address negotiated
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer idle-timeout 0
 dialer persistent
 dialer-group 1
 ppp chap hostname tefomatlho2018@gmail.com
 ppp chap password 0 77529888
ip default-gateway 169.255.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source route-map BTC-LINK interface GigabitEthernet0/0 overload
ip nat inside source route-map REDUNDANCY interface GigabitEthernet0/1/0 overload
ip route 0.0.0.0 0.0.0.0 168.167.50.109 5 track 1
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 169.255.1.1 10
ip sla 1
 icmp-echo 168.167.50.109 source-interface GigabitEthernet0/0
 frequency 10
ip sla schedule 1 life forever start-time now
dialer-list 1 protocol ip permit
route-map REDUNDANCY permit 1
 match ip address 110
 match interface GigabitEthernet0/1/0
route-map BTC-LINK permit 1
 match interface GigabitEthernet0/0
access-list 110 permit ip any any
access-list 110 permit ip 10.10.3.0 0.0.0.255 any
access-list 110 permit ip 10.10.4.0 0.0.0.255 any
access-list 110 permit ip 10.10.5.0 0.0.0.255 any
access-list 110 permit ip 10.10.6.0 0.0.0.255 any
access-list 110 permit ip 172.16.100.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password D!sc0v3ry
 login local
 transport input telnet ssh
line vty 5 15
 password D!sc0v3ry
 login local
scheduler allocate 20000 1000
event manager applet FAIL-OVER
 event track 1 state any
 action 0.0 cli command "enable"
 action 1.0 cli command "clear ip nat trans *"
 action 3.0 cli command "Fail over just occured"
end
HAN-C1921-COM#
there are a lot of things wrong with your configuration. Post a schematic drawing of your network including all connections and IP addressing...
let me do the diagram
HI
i have sent the diagram
Good ! I'll have a look...
here is what I have come up with (important parts marked in bold):
version 15.4
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp-excluded address 10.10.4.1
ip dhcp pool TEST
dns-server 8.8.8.8
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
redundancy
track 1 ip sla 1
delay down 5 up 5
no ip address
shutdown
no ip address
duplex auto
speed auto
ip nat inside
description Main Link
ip nat outside
ip nat inside
duplex auto
speed auto
no ip address
duplex auto
speed auto
interface Dialer1
description Secondary Link
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer persistent
dialer-group 1
no ip http server
ip nat inside source route-map BTC-LINK interface GigabitEthernet0/0.1954 overload
ip nat inside source route-map REDUNDANCY interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 200
ip sla 1
frequency 10
match interface Dialer1
match interface GigabitEthernet0/0.1954
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
password D!sc0v3ry
login local
line vty 5 15
password D!sc0v3ry
login local
end
HAN-C1921-COM#
Thank you very much it worked,
Good to know, glad you got it up and running...
HI
I have put the configuration into a production network, now we cannot get internet with the main link, I can ping and traceroute to my next hop but I cannot go to the next hop.
remove
from your access list 110.
If that doesn't help, post the full running configuration, I want to check if everything is put in correctly...
Also post the output of 'show ip nat translations'
Find attached translation with secondary link down and up. the secondary is working fine.
